Hudson Trailers?
/ Hudson Trailers? #1
Harleazy
Charlotte
John deer
Hi I'm new to forum and very interested in purchasing a Hudson bros Trailer, Looking for feed back on them from several members if possible anyone deal with them any pros and cons ?
Thank you
/ Hudson Trailers? #2
I've had one for almost 10 years not a single issue IMO they are a quality made product.
/ Hudson Trailers? #4
I bought a used one when I bought my B7610 in 2009, an '07 18' Hudson HSE Deluxe trailer - 5 Ton.
attachment.php
Fit just fine for years, mostly unused form 2009 to 2012.
Little bit tight now
attachment.php
Doubles as enclosed with a little work
attachment.php
/ Hudson Trailers? #5
I had an 18' Hudson with hydraulic tilt bed for several years 2003-2007. It was a good unit. If they are still made to the same quality it should be a good trailer. The only issue I ever had was the fuse would blow on the lift battery charging line (from the truck's 7 pin connector). The tilt would slow down as the battery got weaker. That was a common known issue with those trailers. Just had to replace that fuse now and then.
/ Hudson Trailers?
Thanks for the reply's anyone else have any feed back on these
/ Hudson Trailers? #7
I have had two hudson trailers in the last 8 years. The first was a 5 ton metal deck tilt bed. I traded to a 6 ton tilt bed becasue the tail of the trailer was too low to the ground and rubbed on everything. My father bought a 5 ton with ramps and it has worked out great for him. I wish I had gotten a deck over since I haul pallets and other material which is loaded and unloaded with a forklight. I upgraded to a larger excavator and need to move up to a gooseneck trailer. My dealer did not have a Hudson in stock and said it would be 8-10 weeks before they would see one.
I would recommend them without hesitation.
Good luck,
Mike
/ Hudson Trailers? #8
Hudson is a quality manufacturer. They typically rate their trailers as 5 ton, 4 ton, 3 ton, etc...Those ratings are what they will haul. The GVWR is higher. They will price out comparable to a PJ or other higher end manufacturer. Difficult to find a used unit at a decent price.
/ Hudson Trailers?
Well I placed an order through local dealer for a Hudson I'll be picking it up at the manufacturer soon I'll post pictures soon
/ Hudson Trailers? #10
I sold my 7T Hudson goose several months ago. I bought my new goose from Mike Moore Welding which is down the road from Hudson. He used to work for them. A lot happier with his work.
New/Unused Wolverine 78in Quick Attach Land Leveler (A65583)
New/Unused...
2016 Ford Transit 350 Wagon Passenger Van (A64556)
2016 Ford Transit...
2007 INTERNATIONAL 7600 6X4 T/A GARBAGE TRUCK (A66091)
2007 INTERNATIONAL...
HOSE REEL FOR TORCH (A64276)
HOSE REEL FOR...
3-Pt Disk (A66285)
3-Pt Disk (A66285)
2022 EZ-GO ELITE...
