HST-3 ???
/ HST-3 ??? #1
kuboman
Canada
B3200, L5740,
I have a L5740 but how do you tell if it is a series 3 or 2. What year did they change to a 3. There is no designation on the serial # plate.:confused:
/ HST-3 ??? #2
Try the left side of the instrutment housing. Mine has a sticker with the model. After the model number is a -x to show revision.
/ HST-3 ???
Try the left side of the instrument housing. Mine has a sticker with the model. After the model number is a -x to show revision.
No such sticker on mine. You would think the model/serial # plate would show but I can find nothing that refers to the series. Does anyone know the difference between a 2 and 3.:confused2:
/ HST-3 ??? #4
check your purchase info my L5740 said -1 on the dealers invoice and some sticker I tossed. The only thing I have found is -3 have swivel seats and a pto knob.
I just got the -1 owners manual and I have the -3 too so I will read them both and let you know.
/ HST-3 ???
Thanks for the reply's. The reason I need to know is I want to order the third function valve and there is a difference between the 2 and 3 so I need to know. One mechanic told me the 2 and 3 designated the emissions tier but I don't even know that.:confused2::confused2:
/ HST-3 ???
OK I found the sticker, it was pulled off the tractor and put in the owners manual I guess so it would not get lost. The kicker is it has a -1 after the model and I know it is no older than a '09. Can this be explained?:confused:
/ HST-3 ???
OK so I found that the engine was made in July of '09 so I assume the tractor was assembled after that;) That make the tractor either a '09 or '10. The dealer told me it was a '10 so does that make it a series 3 or what??:confused::confused:
/ HST-3 ??? #8
Does your seat swivel left/right? is your pto a lever or knob
Swivel seat/switch =-3 havent heard of a -2 just -1's and 3's
/ HST-3 ??? #9
I just went throught the two manuals I have still havent come across a -2 reference.
Swivel seat, pto knob, valve lock, and a TE3 engine designation(external EGR) = -3
valve lock is a change the hole thing not a lever.
loader installation manual has all the instructions for the third valve install could be there you will see the differences
Manual part number -1 1agawaaapo79a
-3 1agawacap0010 has info on low sulfur fuel requirements
/ HST-3 ???
I don't have swivel seat or pto knob but I do have external egr on engine:confused2::confused2:
/ HST-3 ??? #11
I mis read the external egr part seems all 5740's have it:)
My guess is yours is a -1 like mine maybe your engine sn can be deciphered to find out if its a V2403-M-TE3-HST. I believe the TE3 would make it a -3
Just my thougthts
/ HST-3 ???
Anybody have more insight? My local dealer can't even tell what I have.:confused2::confused2:
/ HST-3 ??? #13
I don't know about the cab models but if your's is an open station you could have a -2. I was told very few were made. Your dealer should be able to take your SN and use it to order the correct parts for you.
2020 Kubota MX5400DT (A64047)
2020 Kubota...
2007 Freightliner B2 School Bus (A61573)
2007 Freightliner...
Arrow Quip Head Holder (A64047)
Arrow Quip Head...
2022 Coyote Renegade Trailer (A63116)
2022 Coyote...
36 BLADE AC CENTER FOLD DISC HARROW (A63291)
36 BLADE AC CENTER...
2025 Unused SDLGC80 Electric Golf Cart (A64194)
2025 Unused...
