Mowing HP needed for mowing
/ HP needed for mowing #11
I've got a 6' finish mower behind a 4300.. about 27-28 PTO HP. The only time I slow down is deep, think grass. I don't really have to, I guess, but you can hear the engine lugging down a bit, and it seems kinder to the equipment to downshift a gear rather than make it work so hard. As for the 2" saplings with a finish mower, I've done up to about 1" without a problem.. I woud guess that 2" wouldn't be a big problem, but I don't know that for a fact. But, in general, the 28 HP and the 6' mower work just fine. I've never had a problem that couldn't be solved by going just a tad slower, and I can count those times on the fingers of one hand. Normally you just set the speed to whatever the terrain dictates (so you don't get bounced around too much) and then just go for it. HTH.
/ HP needed for mowing #12
Maybe this mostly comes back to what my cousin once told me. He said, sure, you can use small tractors, geared way down, and do most the things larger tractors do.. just more slowly. Most farmers can't waste the time to do things slowly. So they need the bigger machines. The rest of us have fun on our tractors, don't particularly mind how fast we get a job done, and so can easily use the smaller tractors.
I'm sure there are exceptions to this rule, but in general I thought he made a good point.
/ HP needed for mowing #13
<font color=blue>…As for the 2" saplings with a finish mower, I've done up to about 1" without a problem.. I woud guess that 2" wouldn't be a big problem, but I don't know that for a fact….</font color=blue>
Yow Bob…!!!
Stop abusing that poor implement… /w3tcompact/icons/blush.gif /w3tcompact/icons/frown.gif
Those finish mowers just don’t have the blade thickness, gearbox output shaft size, & deck/skirt metal proper thickness to hold up to that type of “rough” operation reserved for “rotary cutters”…
I know it sounds kinda backwards… but for less than ½ the average price of a finish mower ($1200)… you can do most of all the above and then some, with a basic rotary cutter ($550.)… and after a few cuts… from a distance, you’d be hard pressed to tell the difference…
Please… treat that finish mower of yours with more TLC… /w3tcompact/icons/wink.gif
/ HP needed for mowing #14
Hi John,
<font color=blue>Those finish mowers just don’t have the blade thickness, gearbox output shaft size, & deck/skirt metal proper thickness to hold up to that type of “rough” operation reserved for “rotary cutters”…</font color=blue>
Well, it's only an occassional little sapling growing around a tree or two.. is this really going to hurt it? You can't even hear a sound when it chops it off.
I had previously asked folks if I should get a brush-hog (is it brush hog or bush hog? I've never been sure...) But everyone told me the bush hog would do a crummy job on the lawn so stick with the finish mower. I dunno... I'm dumb.. ask Franz.. he's met me. /w3tcompact/icons/laugh.gif
/ HP needed for mowing #15
A 6' brush cutter on a 22-25hp pto is marginal for heavy, tall grass (as per prior posts). You can cut 2/3's widths (4') when your engine lugs, but if such is necessary very often, it kind of defeats the point of a 6' cutter. As to 2" saplings, forget a finishing mower, and the blades on many "light duty" brush cutters won't do too well (and neither will the unit, after a while). I've a 5' heavy duty brush cutter on an L3410 GST (28.5hp pto), and have handled lots of 2-3" saplings, very heavy brush, vines and the like without problems - but my engine will require a low gear in the heavy grass I cut once a month. Once I get the property fully "civilized" (without small stumps, brush, irregular ground), and have the time to mow it more often than monthly, I'm graduating to a 6' medium to light duty unit.
Basically, I'd recommend you consider a bit more pto power if a heavy duty 5' cutter, or a light duty 6' cutter in heavy weeds/grass, is intended, especially if you're going the HST route. You can eke by with less, of course.
/ HP needed for mowing #16
<font color=blue>is it brush hog or bush hog? I've never been sure</font color=blue>
Bush Hog = A popular Brand name.
brush hog = generic brush hog, rotary cutter, shredder, rough cut mower, or slasher (depending on what part of the world you live in)./w3tcompact/icons/laugh.gif
/ HP needed for mowing #17
Rick,
You missed something, If Msft made a 6 ft rotary cutter it would require a 750hp tractor to run it....
Just a little fun at Bill Gates and Pete Balmer's expense....
Regards,
Chris
/ HP needed for mowing #18
Great thread. Anyone have a good recommendation for a 5' heavy duty cutter that does not cost the arm and a leg it would lop off, given the chance? Does the gear box hp need to match the tractor pto hp? Finally, is a slip clutch worth the added expense? Thanks for all the great info! I have 13 acres, of which I will clear about 8 acres. It was clearcut 20 years ago and I live in Virginia, so you can imagine what it looks like. If you really want to see it, go to: http://www.people.virginia.edu/~jas5n/adair1.htm And by the way, I'm really much better looking than the guy in the picture--it must have been the camera!
/ HP needed for mowing #19
<font color=blue>Does the gear box hp need to match the tractor pto hp</font color=blue>
GearBox HP= max hp before destroying gearbox
Min Tractor HP= HP range of tractor (PTO HP and aprox weight range)
slip clutch is cheaper than onerhaul
Hey, with a guy looking like that running around, you won't need to worry about varmints/w3tcompact/icons/grin.gif
/ HP needed for mowing #20
Oh, Beautiful place! (but you knew that; its in Virginia/w3tcompact/icons/grin.gif)
2006 International 7400 SFA Terex Hi-Ranger 6TC-65 65ft. Insulated Bucket Truck (A60352)
2006 International...
2025 AGT Industrial ATK-B1000 2 Post Car Lift (A60463)
2025 AGT...
2020 KENWORTH T270 SERVICE TRUCK (A59823)
2020 KENWORTH T270...
2016 Yanmar VIO25 (A60462)
2016 Yanmar VIO25...
2019 GALLEGOS TRAILER PNEUMATIC TRAILER (A60736)
2019 GALLEGOS...
2016 John Deer 5075E (A60462)
2016 John Deer...
