hp needed for genny?
/ hp needed for genny? #21
Frank, It's encouraging to hear that you were able to keep things powered up during your extended power outage with your smallest tractor and lower engine rpm (750 pto speed). most home loads are not going to be that huge on average, sounds like we just need to manage the loads with a little simple planning.
I really like the idea of slower engine rpm's for the obvious reasons, lower sound emissions, fuel use and wear. The tractor I'm using is a spare machine not needed for anything else, I'm gonna start looking for a used kub with 2 speed pto in the 20-30 pto hp range to replace it, nothing fancy, don't need 4x4 or loader, just a low hour power plant.
One more thing, my little testing only involved my shop which has a separate service, have not tried powering up the house yet, I'm a little worried about the computer and DLP TV, should I be? I really don't have any big loads in the house except the stove and dryer, so with a little planning I should have no problem staying within that 58-62 Hz window.
I second the notion for a generator forum, maybe make it an alternate energy, inverter, generator forum to make it more useful and since they are all connected.
/ hp needed for genny? #22
Spot on again Ron! Everything you mention are factors I have weighed during my testing. And boy are you right about that Fan! It moves a tremendous amount of air and I'm sure it is certainly costing me more HP than anyone would initially guess. The L3450 makes an Honest 30HP at the PTO running at 2250RPM on the tack. It is obviously the most stable tractor I have regarding power production. Unfortunately the only other PTO speed available on this tractor is 1000rpm at 2200rpm's. If I throttle it back to 540rpm it's only spinning at 1300+rpms on the tack and this is where that whole inertia thing comes back to bite me. If it had a 750-800rpm PTO setting and would run in the 1800rpm on the tack range, I think I could find a great affordable medium.
One other thing though, when I used the B9200 for those couple of days I was probably running the tractor on average about 10-12hrs out of each day split up across the day in 3-4 hours chunks. Since the hour meter on the tractor only spins a full hour when your running at stated PTO speed, I could run it for about 1hr 20min clock time for every hour registered on the meter. Also, over that 4 days I only went thru between 7-8 gallons of fuel so it was pretty darn economical.
Hopefully all this information is useful to some of the other guys who may be considering PTO gen's or have notions of doing a gear reduction setup and think they will be able to get the comparable amount of power from their sets. Granted, in my case spinning this massive 30Kw head is actually overkill for the smaller machine, but I got a wonderful deal on the generator, SO no complaining from me!
On another note, I have an 8kw ST head that I'm considering mounting directly to a V1105 Kubota engine (approx 15HP at 1800rpms) that I scavenged from a golf course machine. What's stopped me for now is I'm wondering whether the Governor on that engine is going to give me the same NON-results as the Tractors governors. I wonder if Kubota sells a generator governor kit seperately??? Guess I'll have to look into that.
Frank
/ hp needed for genny? #23
If you have a relatively clean power output, you should not have any problem under normal running. Where most run into problem is with a generator with poor waveform shape. Most of the energy is in the peak, so microwaves and switching DC power supplies(most all modern electronics have these) struggle with flat topped or distorted sinewaves. One thing your PTO driven circuitry probably isn't monitoring is over/under voltage. If you should inadvertently run your tractor out of fuel, that large spinning mass will mean a slower spooldown and a longer duration brownout especially if the engine coughs a few times working the last bit of fuel out of it's system. Or if the throttle linkage vibrates loose, your generator may continue to put out power while running way out of specification(low voltage low freq) for quite a while till you can get to it to shut it down or throttle it back up. Brownouts are really hard on electrical devices. 2 things you can do for this are add an over/under protection circuit that cuts power off completely when it goes out of spec, or put all the valuable electronics onto UPSs. This will protect them from excursions away from good power due to generator/tractor malfunction. I have small ones on my entertainment system, my Pellet stove and my computer. A side benefit when on generator power is that if they start beeping, I know there is something I need to investigate.
/ hp needed for genny? #24
JB, in regard to your questions about HOUSE current, most (90%) of my testing has been done on the house side. Generally, things stay pretty consistent in a house setting, or the power draws are smaller. Excluding obviously things like Air conditioners, Water Heaters, Well Pumps, etc. This is where it does get tricky in my opinion, and really what I've been trying to get across in my threads. The PTO gen produces clean, consistent power but unless you have a tractor that the governor works a bit better than any of mine, any large spike source of power is going to require you to go and manually adjust the rpm's on the machine via the throttle control. Then, when that large surge of power usage is over, you'll be OVER-Throttled and have to adjust it back or risk damaging appliances.
I find this to be true even if I run my Bigger machine that should have no problem producing 12-14KW. Matter of fact, I'm sure it will make that power NO PROBLEM, but I have to adjust it to support that with the load on the machine to keep it safe. I can't just get it all spinning nice with no load and ask it to produce 10KW without having to manually adjust it with the Throttle control. Maybe if I had a 60 HP tractor it would be less noticeable, but most guys on this forum are dealing with 20-40 Hp tractors I would say. Once you start doing the gear reduction stuff, things just get finickier.
Good luck and I'd be glad to help with any other questions.
Frank
/ hp needed for genny? #25
RonMar said:
JB4310
You made a comment earlier "then once finished heating, idle it down for the lighter loads, even with the big heat load it should stay pretty steady."
You did mean ideling it down by using a multi speed PTO right? There is no ideling it down in traditional AC power generation. You MUST maintain the generator RPM to maintain the 60HZ frequency output. The governor does this by controlling the throttle based on load to maintain engine RPM. So under a low or no load situation, the governor is using just enough throttle to maintain it's set RPM. That is the drawback of an oversized generator. It is setting there humming away at full song burning fuel to move all those engine bits and generator blower with a very light and innefficient electrical load.
Ron, I was actually talking about just adjusting the throttle downward, since his SIL has an all electric house and to heat that if it's a large house it could be 15-20 kw load and and from what I've learned recently that would take some upward adjustment of throttle from no load to keep it at 60Hz, but having the multi speed pto would be even better.
I'll bet that big engine you have is one of those listers, Ive read a lot about them, and thanks for letting us know how much HP those cooling fans can use up.
/ hp needed for genny? #26
Frank
That sounds like a good combination. I bet if you connect those two together you will get pretty good results. Remember if it will hold +/- a few hertz you will be fine. It would surely be a better combination for sub 5KW loads than that big old 30KW is. That one portable on the 3PH is the one you use to go rescue the neighbors reefer and freezer every day or so:) Leting em heat a tank of hot water and take a shower and keep from loosing all their cold food can go a LONG way in neighborhood relations... As for "NON-results", I wouldn't call yours non results, I would call them perfectly predicatble and right on the money for that horse power/genhead/load configuration. And they are also perfectly adequate to power your home when the commercial provider is unable to. I think the 15HP engine and the ST head will be much more efficient combo though.
The Onan 15KW sets I work with use a 30HP 3 cyl bota engine with a selectable governor preset to run at either 50 or 60 HZ. There is also a electro-mechanical followup device to help stabelize it though. Kubota may make a different gov for yours, but I would run yours first on that generator before I worried about a different governor.
/ hp needed for genny? #27
frankc,
Frank,
I am glad that you posted regarding pto generators. Count me as a vote for a Gen sub-forum. I am in the research stage and I have been looking at Tiger Power for a while. What is your opinion regarding their products and overall service?
My tractor is a Kubota L5030 HSTC producing 43 PTO HP. I am considering the 30Kw Tiger gen for the same reasons the others here have mentioned: increased mass for greater surge.
Our house is all-electric, but I will not need watts for heat since I installed a wood stove with plumbed external combustion air as an emergency heat source. I will use the gen for central A/C and all other household needs.
Along the lines of Ron's suggestion regarding neighborly duties, i was thinking of a carry-all mounted system for portability, but with casters on the bottom to ease storage issues.
/ hp needed for genny? #28
This might might reveal how electronically challenged I am but I have to ask, will those surge protector power strips help with the over or under voltages we are talking about here? or are they only for extremes like lightning strikes, I have them for both my entertainment equipment and office.
If not what size UPS is recommended for average computer or entertainment system? I see them on eBay for anywhere from $29. - $7,500. seen a couple of 450 watters for around $100. would that be big enough?
/ hp needed for genny? #29
A surge protector is just that, for surges of several hundred volts, such as from a lightning strike.
As for a UPS, that is where the Killawatt can really come in handy. Plug your entertainment or computer power strip into it and turn on everything you would normally have on, and you will see their combined electrical need. I have a 700Va on my computer, another 700VA on my entertainment system(42" LCD, sat receiver, stereo system and DVD/VCR combo). A rule that has always served me well is to double the routine load for the UPS. So 400VA of load, and I would use around a 700-800VA UPS. This is a little easier on the batterys so they don't get so overheated, and it gives you a little bit of run time before they shut down.
/ hp needed for genny? #30
RFB said:
frankc,
Frank,
With your tractor, I wouldn't put any more than a 20KW on it. Any more is just a waste IMO as you don't have the HP to carry much more load than that.
It is quite common to over estimate the ammount of power required when sizeing a backup generator. I think if you do a power study, 20KW will be more than enough, including running a considerable ammount of electric heat. As an example, electric baseboard heaters consume about 250 watts per foot. So 10KW will get you 40 feet of baseboard heater. That is enough for several rooms. I doubt your A/C needs a full 10KW. But with 10KW used, that leaves 10KW for all the rest. HW will pull about 4.5KW(when it is on), oven about the same, electric dryer about 5KW, All the rest of the lights, reefer freezer and well pump probably pull less thean 3KW combined(maybe a little more during startups) but not all these things need to be run at the same time. And remember, it is a backup, so you can probably save a bunch of money in the cost difference between 20 and 30KW and still meet all the necessities and then some. Money that can go into a slick carryall mount and a 100 or so gallon fuel tank so you have some fuel on hand when the worst happens and you can't get any at the local pump cause they don't have power. The inertial difference between a 20 and a 30 is probably not all that great also and certainly not enough to warrant the cost difference when you don't have enough HP to make full use of a 30KW.
My .02
/ hp needed for genny? #31
Ron,
Thanks for the input; it will help me to make an educated purchase. I will not be using electric heat (it is forced-air electric) during an outage. I planned the wood stove when I built, and I keep 5 cords as backup. The central A/C is a 4 ton unit, and if the outage is during our 100F+ summer, it will be used. There is one 3 foot 240VAC baseboard heater for the pump house, plus I have a 1hp deep-well submersible pump. All the rest are general household draws, and I planned on load balancing as a basic plan.
One reason I had planned on a 30kw versus a 20kw was for(as you mentioned) the inertial advantage (and because Tiger does not make a 25). I knew about the 2hp per kw guideline, and was also trying to maximize capability in the event I bump up in tractor size.
I already keep keep fuel on-site, we are pretty rural (county seat is the largest with 800; not even one traffic light in a 1400 square mile county).
Do you think the carry-all idea is practical?
/ hp needed for genny? #32
RFB, I'm just learning about this interesting subject and am by no means any kind of authority, but I knew what kind of an answer you were going to get regarding the 30 kw generator, way over size and by your load list I don't think your gonna use half of that 20 kws output. If I had your tractors pto hp, I would go with the 20 kw max, you'll still have hp in reserve and plenty of kw's in reserve.
Mine is only 10 kw, but I don't think I would need more than that, I have oil fired heat and hot water and no well pump just a couple of 1500 watt supplemental heaters, the house is 3000 sq ft and 3 kids so there are a lot of TVs and lights but most of those are now the mini fluorescents, in the summer 20,000 btu's of window AC's.
I don't think we would need to bake a pie during an outage but we could, drying laundry is a necessity, those would be the biggest draws and I might have to cut back electrical use in other parts of the house when using either the stove or dryer but I can live with that.
I got the carry all for mine and thought I would put casters on mine like you mentioned but mine is fairly light enough to just slide around, I'm going to store mine in a climate controlled shop as opposed to just out in a barn, I'll probably tape the vents up to prevent critters from moving in.
Here's a pic of my carry all, I raised it to 12" with higher legs (was only 7") and modded it to hook up to my imatch on another tractor.
/ hp needed for genny? #33
Nice carry-all. Self-made or purchased?
Also, does your generator provide AVR or capacitive regulation?
/ hp needed for genny? #34
I like that sled.
RFB, that 4 ton A/C is going to need 5 or so KW to run, and near double that for a high pressure startup. Depending on it's age, it should have a pressure delay/soft start circuit to take the edge off of the startup draw, and that is only for a few seconds. That is the 10KW I allowed for earlier. I would be surprised if you couldn't maintain a comfortable, almost normal lifestyle on the remaining 10KW. I wonder how much your central heat pulls at full heat mode?
I think 20KW matched with your 40HP tractor would quite happily power your listed situation in almost normal fashion. I also thingk it would do well on a larger tractor as the HP margine will make it a little happier when you are powering that A/C and the poor tractor is laboring outside in the heat... A larger gen head will only increase the HP drain and add load to the engine in the summer time. When it comes to generators, bigger is not better...
And for anyone who is interested, here is a pic of my 3KW monster.
/ hp needed for genny? #35
RFB, I got the carrier from the company I bought the genny from as part of a package, mine is not AVR, I got a couple extra capacitors with the order in case I need them in a hurry.
I'll try to link you to the manufacturer and also the dealer I bought mine thru, the site may say out of stock but she is just having problems updating the page, pto marketplace has component prices listed or you can go to the packages heading.
I noticed tiger power does not offer a carrier, but also noticed that the tiger power 10 kw and the IMD 10kw look identical except for the box's color, the 10 kws have an Italian made Sincro alternator and gear box, the larger units look different.
I think ron was alluding to the idea that you could probably run your electric central heating system with the 20kw, if you wanted to.
RonMar, I like that fly wheeler, are they really as nice sounding as they say? whats the max rpm's 600-800? or is it even less than that? I did a lot of reading on those so called third world engines, stories like villagers working on 30 year old motors with tools made out of animal bones.
PTO Market Place, Your Market Place For PTO Generators
International Manufacturing & Design Home
/ hp needed for genny? #36
Ron,
Love that single cylinder; it reminds me of something like you would see on the "African Queen" (Bogart). The little oiler in the foreground is the perfect accoutrement.
/ hp needed for genny? #37
JB4310,
Thanks for the data point(s). My first choice if I can get it is a gen with AVR.
One of the reasons I am keeping the 30kw model in consideration is because while I am pursuing this project I am also considering going up in tractor size. I am a solid Kubota guy, but I am also a very solid HST guy, and I want something in the 80-100 hp range. The Deere 6420 with IVT(CVT) is one up for consideration. It's not HST, but it's not jamming gears either.
/ hp needed for genny? #38
RFB,
In regard to Tiger Power Gen quality, I have to say that I don't have anything bad to say about them. I did have a problem with my first one where the front armature bearing was real noisy(bad). Lucky for me, I only live 40 miles from the National Distributor of these generators, I hauled it to them, we determined that there was actually something wrong with the CASE, so, they pulled a brand new unit off the shelf and replaced the whole thing. Really nice people actually!
My setup came with a wheeled cart, built like a bricks**t house. Not as compact of a package as JB's SKID, but can't complain about the quality of what they delivered. One thing to keep in mind when deciding which size of GEN to purchase is whether you are getting a 2-pole 3600rpm gen or a 4-pole 1800rpm gen head. I absolutely wanted a 4-pole head, the smallest 4-pole head that Tiger offers is a 20kw, they happened to be out of stock of the 20kw's when I purchased so they made me a REAL GOOD deal on the 30Kw.
Most PTO gen manf. don't offer 4-pole heads on anything smaller than 20Kw. Just by looking at JB's it appears to be a 2-pole head.
JB, I do like your sled setup. I guess we could have a conversation about the +/- of 3ph carriers and wheeled carts. Here's some of what I've determined.
a) Wheeled carts let you move the whole gen by hand to some degree. Like If its blocking something behind it in the garage and you need to get it out of the way. You'd have to be a bigger man than I to move my 400lb 30kw if it was on a skid.
b) Wheeled carts will be harder to keep the PTO shaft straight(in line) with the tractor! This is a factor not only on the Horizontal plane but also the Vertical Plane. Vibration, and Speed up/Slow down when the u-joints are NOT square can affect loss of HP and accelerated wear on the Gen Head.
c) Wheeled carts vertical height is NOT adjustable! The height of the shaft is what it is, if you have different sized tractors and are trying to keep the shaft straight it can become challenging. On the flip side the 3PH carrier can be lifted or lowered with the tractor and you can dial that baby right in. A simple screw jack then put under the skid will stabilize it to the ground and eliminate the possiblity that the 3ph may drift during operation.
RFB, I agree with Ron about 20Kw being enough power to do what you need.
You'd be surprised how little power you REALLY need to just make do. I'm kind of use to not having power as I have a mountain cabin without any commercial power source available for over 7 miles. I spent the first 15 yrs just with Propane fired appliances (lights, stove, refrig) and still prefer the quiet of that solution. But, as the wife and kids get older and I need to provide MORE creature comforts, showering under a heated water bucket isn't cutting it anymore. Granted, we only spend couple weeks a year in that environment, but my family is used to it more than most in todays world.
I have a CATEGORY NAME RECOMMENDATION:
POWER GENERATION
It could be sub-categoried to support solar or generator solutions.
Is there a moderator that could help us make this happen????????
thanks guys
Frank
/ hp needed for genny? #39
Ron,
Thanks for your thoughts about the V1105/8kw St setup. If you think it will work good, I feel more confident that I'm not wasting my time. Your real world experience is VALUED and appreciated. If they do start a GENERATOR CATEGORY, and I do decide to do this project maybe I'll chronicle it.
The engine is still in a 4wd reel mower that starts right up and drives great. The reels were (sold all that stuff) powered by a separate hydraulic pump than the wheel drive(hydrostatic pump). So, I thought I'd pull the separate Hydraulic pump off and design a way to use that PTO to drive the generator direct, while keeping the ability to still drive this thing. Talk about rolling power source, ha ha.
In regards to my neighbors, I'm a redneck in the midst of yuppie land, I think they all wake up in the mornings and over coffee have the what's he up to today laugh. BUT, when the sh*t hit the fan after that summer storm, my house ended up being the community congregation site. If I wasn't fixing other peoples generators(mostly gummed up carbs) I was fixing chainsaws since we had alot of tree damage. So, everyone more or less tolerates me because they figure I'm their last line of defense when everything is going bad.
Frank
/ hp needed for genny? #40
Are you up towards the Council area? or more north?
