How would you use this????
/ How would you use this???? #1
Anonymous Poster
Epic Contributor
I found this on Ebay and was wondering how you would use this type of saw........Just though that one of you guys would know somthing about this.
http://cgi.ebay.com/aw-cgi/eBayISAPI.dll?ViewItem&item=1602515412
I hope that works, I can not figure out how to get a pic. to post. Sorry.
<P ID="edit"><FONT SIZE=-1>Edited by edgeman56 on 06/05/01 09:18 PM (server time).</FONT></P>
/ How would you use this???? #2
edgeman,
This saw mounts on the front-end of an old narrow-front row-crop type tractor. The pulley is driven by a 6" canvas belt from a mid-pto drive pulley on the side of the tractor. When I was a kid we had one on our JD Model B. The saw is used for cross-cutting logs. We used ours for cutting firewood.
Larry
/ How would you use this???? #3
I used one of them in the 60's. The flat portion, (with the edge) is a tilt-table, would hold the wood (log) and rock into the blade. Back in it's heyday, chainsaws were not as cheap or plentiful, and many people, me included, used two man hand saws to fell the trees and cut to length, then you could use the cordwood saw to save wear and tear on the chainsaw (if you had one). Typically you would have pre cut your firewood to a size you could lift, 5 " in diameter or less and 6 or 7 feet long. Drag it out of the woods and use the cordwood saw on the front of a tractor (I used a Case DC or SC). The saw blade was powered off the side pulley by a 8" canvas belt, spun around 1000 RPM and had (as pictured) NO GUARDS ON ANYTHING! Imagine a 24" diameter blade spinning at 1000 RPM with 30 or more HP behind it! Why none of us got killed (or lost any limbs) is beyond me, other than the fact that we operated the equipment with LOTs of respect.
I still have that saw stored up in the loft of the hog pen. Don't thing I have the desire to ever see that thing spin again.
Steve
(3) Good Year 480/80R38 Tires w/ Rims (A60463)
(3) Good Year...
ALLMAND LIGHT TOWER (A60736)
ALLMAND LIGHT...
Trimble Guidance System (A60462)
Trimble Guidance...
3PT 10' Rolling Cultivator (A60462)
3PT 10' Rolling...
2021 Kubota SVL75-2 Track Loader (A61307)
2021 Kubota...
2023 Kubota RTVX1120 (A60463)
2023 Kubota...
