How would you fix this? Road washed out...
   / How would you fix this? Road washed out... #21
We had a hundred year flood a couple of years ago and the culvert serving the creek that flows through our property was blocked by debris, and the water overwhelmed/eroded the earth over the pipe. I had the metal pipe, which was corroded badly, replaced with a larger plastic one, and sourced two large (ton each) concrete blocks that act as an anchor on each side of the pipe upstream. Large rock was stacked on each side and over top of the concrete blocks and the pipe was then buried with dirt/rock. I'll take a pic when I can and post it. I would go much bigger with the pipe the OP is replacing, as debris blocking the mouth of it will cause overflow next time and the same thing will probably happen again.
   / How would you fix this? Road washed out... #22
   / How would you fix this? Road washed out... #23
When Hurricane Irene hit Vermont in 2011, the majority of damage was caused by either blocked culverts as you mention, or trees jamming against bridges which caused erosion around the abutments and washed out the entry and exits of the bridges. Afterwards, all the affected culverts were pulled and replaced with much larger units.
They have not yet been tested:eek:
2017 Chevrolet Express 2500 Cargo Van (A59230)
2017 Chevrolet...
HIGH END MINI GOLF CART (A58214)
HIGH END MINI GOLF...
2021 Billy Goat F902H Walk-Behind Debris Blower (A59228)
2021 Billy Goat...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
2005 Jeep Patriot SUV (A59231)
2005 Jeep Patriot...
2015 GENIE GS-4047 ELECTRIC SCISSOR LIFT (A52706)
2015 GENIE GS-4047...
