How to tell if it's the battery or the cable?
   / How to tell if it's the battery or the cable?
SOLVED! Re: How to tell if it's the battery or the cable?
Starter isn't dead-shorted (no continuity) so the extreme battery voltage drop under load pointed to bad battery. Took it out and put in truck battery - tractor started right up!
Not sure I've ever seen a battery before that would hold a charge and show proper no-load voltage, but fail to produce current under load. If it had a bad cell, the voltage should have been off, or so I thought.
Anyway, the answer to my original question (thread title) is: Swap the battery out and re-test.
Thanks for the help and pointers. I'll be replacing the power cable anyway, as it is old and the connector is looking pretty dubious. Really glad I don't have to mess with the starter.
   / How to tell if it's the battery or the cable? #12
Re: SOLVED! Re: How to tell if it's the battery or the cable?
Not sure I've ever seen a battery before that would hold a charge and show proper no-load voltage, but fail to produce current under load. .
that's a REAL common failure mode.
static voltage good.. just no nads.. ;)
glad ya got it licked.
2018 John Deere TX (A53317)
2018 John Deere TX...
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
Grove 4x4 Rough Terrain Hydraulic Crane (A55851)
Grove 4x4 Rough...
Forklift (A59228)
Forklift (A59228)
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
