How to tell if it's the battery or the cable?
   / How to tell if it's the battery or the cable?
SOLVED! Re: How to tell if it's the battery or the cable?
Starter isn't dead-shorted (no continuity) so the extreme battery voltage drop under load pointed to bad battery. Took it out and put in truck battery - tractor started right up!
Not sure I've ever seen a battery before that would hold a charge and show proper no-load voltage, but fail to produce current under load. If it had a bad cell, the voltage should have been off, or so I thought.
Anyway, the answer to my original question (thread title) is: Swap the battery out and re-test.
Thanks for the help and pointers. I'll be replacing the power cable anyway, as it is old and the connector is looking pretty dubious. Really glad I don't have to mess with the starter.
   / How to tell if it's the battery or the cable? #12
Re: SOLVED! Re: How to tell if it's the battery or the cable?
Not sure I've ever seen a battery before that would hold a charge and show proper no-load voltage, but fail to produce current under load. .
that's a REAL common failure mode.
static voltage good.. just no nads.. ;)
glad ya got it licked.
2023 New Holland CR10.90 Combine - 330 Engine Hours - 251 Separator Hours (A56436)
2023 New Holland...
New/Unused Quick Attach Rock Hammer (A57454)
New/Unused Quick...
2024 Yakta YXR610 Zero Turn Lawnmower (A57453)
2024 Yakta YXR610...
1997 DORSEY AIDT-LSCG 53 FT DRY VAN TRAILER (A59575)
1997 DORSEY...
New/Unused Pallet of Ground Protection Mats (A57454)
New/Unused Pallet...
2020 MACK P164T (A58214)
2020 MACK P164T...
