How to tell if it's the battery or the cable?
   / How to tell if it's the battery or the cable?
SOLVED! Re: How to tell if it's the battery or the cable?
Starter isn't dead-shorted (no continuity) so the extreme battery voltage drop under load pointed to bad battery. Took it out and put in truck battery - tractor started right up!
Not sure I've ever seen a battery before that would hold a charge and show proper no-load voltage, but fail to produce current under load. If it had a bad cell, the voltage should have been off, or so I thought.
Anyway, the answer to my original question (thread title) is: Swap the battery out and re-test.
Thanks for the help and pointers. I'll be replacing the power cable anyway, as it is old and the connector is looking pretty dubious. Really glad I don't have to mess with the starter.
   / How to tell if it's the battery or the cable? #12
Re: SOLVED! Re: How to tell if it's the battery or the cable?
Not sure I've ever seen a battery before that would hold a charge and show proper no-load voltage, but fail to produce current under load. .
that's a REAL common failure mode.
static voltage good.. just no nads.. ;)
glad ya got it licked.
1983 Ford 8000 Tandem Grain Truck (A59814)
1983 Ford 8000...
2021 SANY SY265C LC LONG REACH EXCAVATOR (A59823)
2021 SANY SY265C...
19008 (A56859)
19008 (A56859)
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
excavator trenching bucket- one bucket per lot (A56436)
excavator...
