How to slow down hyd cyl travel
   / How to slow down hyd cyl travel #1
jwhite
Eastern West Virginia
NH TC33D
I have a Bush Hog 742H backhoe on a NH TC33D tractor hooked to the tractor hydraulics.
Even with the tractor rpms only at about 1100, the side to side backhoe swing it way too fast. Is there some easy way to slow this down? Some flow restrictor or something?
Thanks!
Jay
   / How to slow down hyd cyl travel #2
On a previous backhoe I installed blunt fittings in line with the cyls. you drill a small hole in the fitting and the place in line, slows down the flow of oil and therefore slows down responsiveness. I installed them on my swing cyl.
Joel
   / How to slow down hyd cyl travel #3
I'll defer to the experts on the proper way to slow it down but I previously was advised to used smaller flex lines to function as restrictors on my T&T. It works fine.
   / How to slow down hyd cyl travel #5
get the schematics for it alot of the valves have flow controls built in and just sitting there
tom
   / How to slow down hyd cyl travel #7
Sorry for the above. Tompkins makes restricted orifice fittings. They are made specifically to do what you want.
   / How to slow down hyd cyl travel #10
Here is an adjustable restrictor like Kenny describes. This is a Parker P600
steel....the one on the right. You only need one, but finding a place to
mount it is little harder.....
My hoe swings plenty fast, too, even with 1/4" hoses all around. I usually
try to operate another valve at the same time so flow is shared.
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
Case 1150G Crawler Tractor Dozer (A50322)
Case 1150G Crawler...
2012 KENWORTH T800 DAYCAB (INOPERABLE) (A50854)
2012 KENWORTH T800...
2016 Case CX55B Mini Excavator (A49461)
2016 Case CX55B...
2019 CATERPILLAR 326FL EXCAVATOR (A51242)
2019 CATERPILLAR...
Husky GHM105890 Cement Mixer (A49461)
Husky GHM105890...
