I have a Bush Hog 742H backhoe on a NH TC33D tractor hooked to the tractor hydraulics.
Even with the tractor rpms only at about 1100, the side to side backhoe swing it way too fast. Is there some easy way to slow this down? Some flow restrictor or something?
Thanks!
Jay
Hydraulic fluid will only flow as fast as the circuit will allow. This is dictated by the pump volume, valve size, and hose size. Speed of the cylinders are controlled by the valve. You can let fluid flow at 8 GPM, or 1 GPM, but that is all controlled by hand. With what you have now, you have full control, but all the way is to fast for you. What you have to do is restrict the fluid flow as has been suggested. Yes, you can use a flow restrictors in-line, which is like a washer with a small hole in it, and the size of the hole will determine the volume. If you want more precise control, then you install a needle valve to set the flow. One day you might want things to work faster, and you simply adjust the needle valve. Other days, you are on your slow day, and want to be more precise, with no jerking the boom around. You only need one needle valve, a nipple between the main valve and needle valve and an adapter, perhaps a pipe thread to JIC adapter for the hose. The fluid that goes through this valve has to come back out this valve, and therefore only one needle valve is required. Doesn't matter which hose you mount it on. You are simply pushing one cylinder out and pushing the other cylinder in. There is not a whole of gravity force here, just swing the boom to center or left, or right. Check valves are not required in this circuit, you want fluid to flow as free, and as fast as the smallest orfice will allow.
Not only have you limited the speed of the boom swing, but you now have the variable setting of the neede valve, and also the hand lever on the valve itself from zero flow to the max setting you have set on the needle valve. Now, you have full control, and as precise as you want to be.
https://www.surpluscenter.com/item.asp?UID=2009071406440520&item=9-5302-38&catname=hydraulic
