How to replace a hyd quick connect fitting?
   / How to replace a hyd quick connect fitting? #1
ddailey
Malvern, ar
John Deere 4310
The fitting for an add-on grapple caught in the front loader mechanism and was smashed. Does the connector just unthread? Will hydraulic fluid run out when un-threaded?
   / How to replace a hyd quick connect fitting? #2
As long as you didn't egg the threads, it should spin off. If you can't get it removed, cut the hose and put a repair end on, or take it to a hydraulic line shop and have them swage another on it.
You'll have some oil in there, but it shouldn't be under pressure if you bled it down before removing it.
Thanks Jim. It went just as you said.
M998 (A55852)
M998 (A55852)
Meyer 8' Snow Plow w/ Bracket (A55272)
Meyer 8' Snow Plow...
Pickup Truck (A59230)
Bins of Monitors, Stands and Dock Stations (A56860)
Bins of Monitors...
1981 LINK BELT HSP 8028 (A58216)
1981 LINK BELT HSP...
20ft Jumper Cables (A57454)
20ft Jumper Cables...
