How to replace a hyd quick connect fitting?
/ How to replace a hyd quick connect fitting? #1
ddailey
Malvern, ar
John Deere 4310
The fitting for an add-on grapple caught in the front loader mechanism and was smashed. Does the connector just unthread? Will hydraulic fluid run out when un-threaded?
/ How to replace a hyd quick connect fitting? #2
As long as you didn't egg the threads, it should spin off. If you can't get it removed, cut the hose and put a repair end on, or take it to a hydraulic line shop and have them swage another on it.
You'll have some oil in there, but it shouldn't be under pressure if you bled it down before removing it.
Thanks Jim. It went just as you said.
FOUR RACKS OF MISC FILTERS (A68842)
FOUR RACKS OF MISC...
2009 ALLMAND MAXI-HEAT MH1000 HEATER TRAILER (A67714)
2009 ALLMAND...
Unused HLA HD42 48in. Forks and Frame Skid Steer Attachment (A66734)
Unused HLA HD42...
2014 ALLMAND MAXI-HEAT PORTABLE HEATER / GENERATOR UNIT (A67714)
2014 ALLMAND...
2013 Freightliner Cascadia (A68134)
2013 Freightliner...
2016 JOHN DEERE 331G SKID STEER (A65056)
2016 JOHN DEERE...
