How to replace a hyd quick connect fitting?
/ How to replace a hyd quick connect fitting? #1
ddailey
Malvern, ar
John Deere 4310
The fitting for an add-on grapple caught in the front loader mechanism and was smashed. Does the connector just unthread? Will hydraulic fluid run out when un-threaded?
/ How to replace a hyd quick connect fitting? #2
As long as you didn't egg the threads, it should spin off. If you can't get it removed, cut the hose and put a repair end on, or take it to a hydraulic line shop and have them swage another on it.
You'll have some oil in there, but it shouldn't be under pressure if you bled it down before removing it.
Thanks Jim. It went just as you said.
2023 CRUISER RV SHADOW CRUISER (A67714)
2023 CRUISER RV...
2017 Ford F-750 Petersen TL3 Forestry Grapple Truck (A66736)
2017 Ford F-750...
2019 Ford F-450 Knapheide Crew Cab Service Truck (A66736)
2019 Ford F-450...
2009 MACK CHU613 (INOPERABLE) (A67714)
2009 MACK CHU613...
1999 INTERNATIONAL 4900 (A67714)
1999 INTERNATIONAL...
Unused 2022 HLA 60in. Hydraulic Root Rake Grapple Attachment (A66734)
Unused 2022 HLA...
