How to remove broken bolts from your mower
   / How to remove broken bolts from your mower #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
So I will start this thread, and I am sure lots of people are going to have their own versions of fixes.
First, my machine is 1850 with a 96" three head rough cut mower. I break off 6 to 10 blades a year. One major modification is that I run with 1/2" blades instead of 1/4 or 3/8" blades.
The design of my 1850 is relatively simple. Bolts with washers hold blades (with bushings in the blades for reduced wear). The hub itself I have no idea on the source, it appears to be custom made. The bottom plate onf the hub has 4 holes. On the other side of the holes are regular 5/8" nuts, tack welded in 3 spots. The hub itself has been tapped (meaning that the metal plate, the threads continue through to the nuts that hold the blade). The hub has a trailer wheel shaft that goes up through the bearing block to the pulleys. the bearing block is a simple trailer axel bearing block, and is bolted to the deck of the mower. above that is a nut that hold the whole thing together, followed by a pulley (and in the center a love joy). None of this is well designed IMO, but to hold costs down, probably the best choice.
OK, the point of my note was to review my methods of bolt extraction.
So setup. I am at the point where I just lift the mower up, do my work off the arm and put it down. If I run into trouble I will flip the mower over which is kind a magilla but having the mower upside down makes it so much easier.
Let me work backwards from where I am at now to the start.
I have gone ahead and cut 3 holes around 3" in size over top of the mower deck where the spindles are. Measure carefully, and consider things that will be in your way. This does allow more water into the mower deck if you let your mower sit out like I do. It also allows debris in.
I then purchase longer 5/8 Bolts to hold my blades on, so they poke through the nut further. I use Grade 5, they have a bit of a shoulder on them so be careful if you go this route. I then made a custom tool, I got a long 5/8 bolt and welded on a nut part way threaded onto the bolt. This is my "Driver". So I break a bolt. Instead of trying to extract it, I thread this bolt onto the broken bolt trought the hole in the mower deck and use my impact driver to drive it down. It won't go very far but at least with a 1/4" hanging out, I can get Vice Grips on the bolt and work it free. now I have had the misfortune of once not getting the driver tool properly threaded onto the broke bolt. I was going to fast trying to get back to mowing. I hit it with the impact wrench, went to the other side with the vice grips and now it is stuck. Stuck in both directions cause the other side was bunged up by my driver, and now the blade side was bunged up by my vise grips. This caused a complete tear down.
Now I only recently (in the passed 4 years) did this method. Prior to it I did as follows.
Remove the hub and cut out the nut. Royal PITA. But self explanatory. When you put in a new nut it is a bit truck as the hub is threaded so make sure you don't over tighten the nut to the bolt before you weld (It creates a bit of a lock).
Drill and use an easy out - Results were never very good. You really need a mag drill. But I woud drill, but a tap in, work it out enough to get vice grips on it. Really a PITA with grade 5 and impossible with grade 8.
Score with a Saw. So I would take a 4" angle and try to score the head of the bolt enough to get purchase, best case with a screw driver. Generally what I would do is get is score the broken head enough to use a punch and tap the bolt in the proper direction to unscrew it (not sure if this method makes sense or not).
Examine the break Sometimes I would get lucky and the bolt wouldbreak in such a way that there was a "tab" of metal I could use my metal punch on to drive the bolt out.
Weld on a nut - this became my favorite method prior to the holes being cut, but given my welding skills I had to flip the mower over. I would take another 5/8 or 1/2 inch nut and put it over top of the broken bolt. I would then grab my stick welder and put a ton of heat down in the center of the nut onto the bolt and fill the weld up. Then put a wrench on it (Impacts tend to tear the welded nut off but then again I am a terrible welder). This heat would also help break the bolt free. But it was not drama free. Many times my welding skill let me down and I would not penetrate the bolt below, or I would melt the nut and then not be able to use my wrench or driver.
Lubricants, Waxes and Torches. So heat is your friend, but remember you have to heat through the hub to the nut on the other side. So getting the hub glowing hot doesn't always get the nut hot. You can spray with lubricants, but you need to make sure you still have a way to get them out. Letting stuff soak is the key, like overnight at least. Waxes are sort of an old farmers trick. You heat with a torch then apply some candle wax. Wax will go down really far and break up the rust. None of this stuff works well for me, but heat is an important. Even if you do not have a oxy set, a simple plumbers MAP gas copper welding rig will be fine.
Think that covers it. Wish I was home would provide pictures (will look to see if I have any anyway).
   / How to remove broken bolts from your mower #2
We had this discussion back in 2015. Here's what I do on the 48" brush cutter for the PT425. It's a single hub design.
MossRoad said:
I just take an air impact wrench and a crescent wrench and remove the two hydraulic motor bolts and get that out of the way. The upper lovejoy section stays on the motor shaft. Then I loosen the allen screw on the lower lovejoy section. Then the impact wrench on the 5 lug bolts and the whole spindle drops to the ground. I stand between the two front wheels, grab the caster arms, do my best Bill Kazmaier impersonation, and lift the deck up and walk it backwards to get it over the spindle.
That whole process only takes about 5 minutes. Then I just back the broken bolts out the rear with those jam nuts and a crescent wrench.
To put it back on again, I just to it in reverse order. If all goes well and I have all the parts, its 15-20 minutes.
I'd rather convert it to a design where the blades can't whack each other's mounting bolts and be done with it.
I have to wonder, though, about blade length. The PT design has long blades and a narrower center drum. The bush hogs I've been looking at have short blades with wider center drums. The blades are gull winged and since they are also short, they can't hit the other blade or blade bolts. But I wonder if the shorter blades have the knock down power of the longer PT blades? I'd hate to convert it only to realize I can't destroy brush as well as the PT does now.
This time I did put in 2.5" bolts with long spacers in the spare holes on the drum. I'm hoping I can sacrifice those and they'll stop the blade from hitting it's partner's mounting bolt. They look to be down a bit lower than the blade bolt heads. I'm guessing they'll hit some rocks or stumps before the blade mounting bolts and I'll hear it and back off before the damage is done. I'll give it a test later this week or weekend and see how it goes.
The jam nuts I'm talking about here...
MossRoad said:
Here's a trick that works well for me to remove a broken brush hog bolt on my PT425 48" brush hog.
I replaced the stock bolts with 2.5" bolts the first time they broke. That leaves about a 1.5" stub inside the hub. I use jam nuts and a wrench to back the broken bolt out from inside the hub.
It takes about 20 minutes if you use air tools and your compressor doesn't toss a belt, break its tensioning device and your kid doesn't spring a last minute 5 mile cross country training run on you that you have to follow on yuur bike. Then it takes 4 hours.
Some pictures of the jam nuts on the back-side of the broken blade bolts...
279316d1346731456-pt425-48-brush-hog-broken-1-jam-nuts-stud-jpg
279317d1346731462-pt425-48-brush-hog-broken-2-jam-backing-out-2-a
279318d1346731466-pt425-48-brush-hog-broken-3-jam-all-out-jpg
   / How to remove broken bolts from your mower #3
Then, last July, I'd had it with dropping the spindle, so I also cut a hole in the deck....
MossRoad said:
After a couple more broken bolts, I, too, gave up and drilled a 1.5" hole through the top of the deck right in front of the hydraulic motor, in-line directly above the arc of the circle that the blade mounting bolts make, and use forceps to place a nut onto the back of the broken bolt and drive it out with the impact wrench.
So I use my forceps and set just one nut onto the back-side of the broken bolt through the hole in the deck. I get it threaded on all the way, then use a deep well socket on my impact wrench and TIGHTEN the nut down, which ends up driving the threaded broken bolt UP and out. Worked good! :thumbsup:
Here are some pix of the holes. Realiing my computer is a mess and I now take too many pictures with my phone that never get categorized.
   / How to remove broken bolts from your mower #6
Thanks! That looks the same as my hub. I only have one. You have three. How long are your blades? Mine cover 48" including the hub.
   / How to remove broken bolts from your mower #7
I broke the bolt holding the blade on my brush hog , I used left hand drill bits and drilled in reverse . Worked like a charm, I have mentioned this method before in a thread.
   / How to remove broken bolts from your mower #8
I used my brush hog for 2 hours Saturday and didn't lose ANY parts!
Well, that's only because I found them after I noticed they'd gone missing.
Lost two lynch pins on the left front caster.
Lost the left front caster.
Lost 3 of the caster spacers.
Noticed a blade hanging low and lost the nut holding the blade bolt.
But I found everything!!! :laughing:
2009 Landoll 435A 50ft. 43 Ton T/A Tilt Deck Equipment Trailer (A60460)
2009 Landoll 435A...
2018 VOLVO VNL TANDEM AXLE DAY CAB (A59905)
2018 VOLVO VNL...
2020 INTERNATIONAL MV607 26FT NON CDL BOX TRUCK (A59575)
2020 INTERNATIONAL...
2014 Chevrolet Express 3500 Cargo Van (A55852)
2014 Chevrolet...
2003 UTILITY TRAILER MANUFACTURER UTILITY TRAILER MANUFACTURER (A55745)
2003 UTILITY...
UNUSED FUTURE HYD HEDGE TRIMMER (A52706)
UNUSED FUTURE HYD...
