How to prepare a plot?
   / How to prepare a plot? #1
Jordan9682
Southwest sk
New holland 9682
What technique/order do you use when making a plot? Assuming its not rock hard dirt.
Does disc, spread seed/fert, harrow,then pack sound right? (Cereal crops blended)
   / How to prepare a plot? #2
If you are using a light disk that doesn't cut very deep that will work. If your disk cuts deeper than you want the seed I would disk,harrow,seed, then cultipack.
   / How to prepare a plot? #4
I assume you already did a soil test and limed and fertilized as needed. One thing I did not realize before starting with food plots is that if you need to raise the pH a large amount (from the 4s), it takes a couple of years to raise it.
I also use pallets with cinder blocks for weight as a poor mans cultipacker. It works much better than I thought when I first tried it.
I'm just wondering about the process involved, and if what I'm thinking about doing would work?-
1) disc, to break up soil and kill weeds
2)spread seed, fertilizer(if needed)
3) harrow, to cover seed
4) pack, for good seed to soil contact
   / How to prepare a plot? #6
Looks good, thats how thousands of hunters do it every year.
I think you could do without the harrow if needed, 5-7 tires wired together would blow your mind how well it works, just floats over the ground. (wired in a pyramid). Of coarse it works best if you disc well.
Great. Can't wait till the snow melts and i Can get at it :D
   / How to prepare a plot? #8
Jordan, dont let a little "powder" keep ya out of the field:laughing:
Hey, I thought you "Northerners" planted in the snow so the seed would come up after thaw?? Seriously I have heard that, may have applied only to grass seed.
Fall rye, winter wheat, winter barley, grass, etc. to answer your question, we seed some crops (as I listed) in fall, not through snow. It's pretty hard to seed through frozen dirt:hissyfit: and it comes out of the ground in fall, but one an inch or two. But does all its growing the next year. Nice for harvest to spread it out abit, they are mature before your spring seeded crops.
   / How to prepare a plot? #10
I'd spray weed killer after step 1 to kill the weeds discing did not.
2005 Northwood Artic Fox 29V T/A 34ft. 5th Wheel Travel Trailer (A55853)
2005 Northwood...
CONTACT INFO LOT NUMBER 6 (A53084)
CONTACT INFO LOT...
2007 Ford F-550 Crew Cab 11ft Flatbed Truck (A55852)
2007 Ford F-550...
2016 MACK CXU613 MID-ROOF SLEEPER (A55745)
2016 MACK CXU613...
2012 CATERPILLAR 305DCR EXCAVATOR (A52707)
2012 CATERPILLAR...
2017 FORD F-450 XL BUCKET TRUCK (A57192)
2017 FORD F-450 XL...
