Backhoe How to load a backhoe
/ How to load a backhoe #1
ccsial
Veteran Member
NorthWest Illinois
(Kuboto L3400) (Ford 1900 4WD w/FEL) (Deere X748SE) All bought new
I couldn't figure out how to put the pictures in the post so I had to attach it but it's worth viewing.
/ How to load a backhoe #2
Holy Macaroni!! You better have a big pair of stones to be anywhere near that machine. Is this common practice in the US??
/ How to load a backhoe #3
After he got the rail car empty, how did he get the tractor out of the rail car???
ron
/ How to load a backhoe #4
Next time get a belly dump rail car. Was that a rental BH? Might explain some bulging metal or hydraulics. :mad:
/ How to load a backhoe #6
I do this all the time - of course I do it on a trailer that is only 16 inches above ground!!
/ How to load a backhoe #7
I've seen video of guys doing some pretty wild stuff with backhoes. What I want to know is how long it took to learn the technique? I mean do you count it off in days, weeks, months, wrecked hoes, dead operators?
jb
/ How to load a backhoe #9
I just wonder how he gets his balls in and out of the cab...
/ How to load a backhoe #11
man., you not going to talk me into trying anything like that!
/ How to load a backhoe #12
After watching the video, it's a pretty simple system. They have special plates that wrap around the top of the rail car to guide the BH along. Once they get the BH lifted up they then PUSH the rail car into the BH and tada we have a BH on top of the rail car, being guided by these plates. I'm not saying something couldn't go wrong, but I'm guessing if done slowly it's ok.. Besides, if OSHA hasn't said nothing.. It's gotta be ok. Right? :D
Wedge
/ How to load a backhoe #13
So are guillotines...haha!
I think the pucker factor happens between photos 3 and 4. You're right, it's probably safer than it looks, but still craaaaaaaaazy.
/ How to load a backhoe #14
You want some craaaaaazy pucker factor check this guy out.I wonder if he comes down for lunch or waits till the end of the day.
Now that looks really crazy. I guess your OK since your being suspended but...If that wall breaks loose, I bet it is still quite a ride.
It would be more fun to just "blow it up"
/ How to load a backhoe #16
Couldn't figure out how the operator got the machine onto the car, once level, as it looked like he wouldn't have enough throw with the boom/stick. I finally saw the cable pulling it, must be a winch on the tractor. It's a REAL good thing they supply operators with those rigs...
Jim
/ How to load a backhoe #17
By utilizing the space freed up by his small brain.
/ How to load a backhoe #19
It (referring to the original backhoe-like machine) is a purpose-built machine for a specific application. I looks like it rides on the rails so it is likely a lot more stable and safer than it first appears. That and it uses a trained operator provided with the equipment.
Now, trusting my life and machine to that crane cable while I demolish a stack below me, that would scare me!
/ How to load a backhoe #20
If I remember right, the method used with the excavator on the stack is that they chip 3 notches in the top equally spaced around the edge. The first notch looks done. The crane then lifts the excavator only alittle bit and the operator uses the boom to rotate the rig so the three H bean arms drop into the notches. He then knocks off the three high sections so everythin is level and starts the process again.
99 percent of the time the crane cable is only acting as a safety. There is no dead weight being suspended. The excavator is always supported by the three arms.
