Snowblower how to keep snowblower higher?
/ how to keep snowblower higher? #1
mrutkaus
Platinum Member
15 mi. N. of Winchester VA
Kioti CK30HST, Kubota BX-1500,
woods 74" blower on gravel drive...
would like to keep it abt 6" higher than the skids do to avoid big rocks
add 2 swivel wheels (like fm rolling tool chest) by drilling hole in bottom of skid?
make taller skid?
just keep it up with hydraulics?
mike
/ how to keep snowblower higher? #2
Taller steel skids if you want it to last.
Swivel wheels will just get ripped off.
Hydraulics wont do the job very well as the tractor goes up and down over bumps which will exaggerate the movement the blower makes as far as height above the ground is concerned.
Dave M7040
/ how to keep snowblower higher? #4
I agree with Dave and would suggest adjustable skids. I also use a blower on a gravel drive but only need 2-3 inches to avoid the gravel. Setting the blower to 6 inches will leave a lot of snow on the driveway. I take a walk just before the snow really starts and toss the larger rocks off the road/driveway before the season starts.
/ how to keep snowblower higher? #5
I did something similar with my Meteor blower. I added a set of larger adjustable skids to keep it from digging in.
/ how to keep snowblower higher? #6
I initially set up my snow blower level front-to-back, adjusted the skid shoes for
approximately zero clearance between the cutting edge and level ground, then
shortened the top link to raise the leading edge up about an inch or so until the
ground was frozen, then lengthened the top link to level the snow blower front-
to-back. I have a gravel driveway, and this seems to work, just about eliminating
gravel pickup. Oh, and as Joeyd stated, walk along the driveway prior to snow
blowing season to pick up any large loose rocks.
/ how to keep snowblower higher? #7
I think the skids or a set of sled runners would work great.
/ how to keep snowblower higher? #9
I found a picture of the add-on skids I made and yes, I tilt mine back also. It helps.
/ how to keep snowblower higher? #10
Just shorten the top link to the shortest for the first pass of the season.
What's left on the ground will pack and freeze solid, then you can adjust the top link back for a clean path.
Simple , effective and free.
Been maintaining our gravel driveways like that on the farm for 3 generations without an issue.
/ how to keep snowblower higher? #11
Top link here too. Makes a big difference.
/ how to keep snowblower higher? #12
Same here for the top link. 6" is a lot to leave behind. just get the wife to pick the rocks before the snow fly's. See how that works out for ya. HAHAHa
/ how to keep snowblower higher? #13
I'm assuming you are using this to snowblow trails or woods roads? I don't imagine you have up to 6" rocks in your driveway. :confused3:
went out and adjusted top link as a result of suggestions, would have taken mw a while to figure out.
mike
Hays LT1 Tender (A61307)
Hays LT1 Tender...
iDrive TDS-2010H...
2022 Bobcat MT100 (A64126)
2022 Bobcat MT100...
213088 (A64276)
213088 (A64276)
generator trailer (A61569)
generator trailer...
2006 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2006 Ford F-150...
