how to increase traction
/ how to increase traction #1
fsteyer
Vermont
Mitsubishi D2000
Hi -reason I got a compact was to pull logs from my woods. Since I cut selectively I need a smaller tractor to get around. But I would like to improve my traction , so if you have any suggestions I'd appreciate it.
thanks
thanks
/ how to increase traction #3
I do it by using the iMatch to carry a set of logging tongs, and the weight of the log will give traction. Care to feather the lift to match the weight on the front end (I do this with either the snow plow or the FEL attached) is important.
/ how to increase traction #4
/ how to increase traction #5
get a set of agressive mud/snow/ice chains. You want the kind that has connections between the cross links, so they don't get between the tractor treads. They make a big difference. Also, fill the rear tires if not already done. Front weights and rear wheel weights.
You will leave deeper tracks, but won't spin holes into the ground.
jb
/ how to increase traction #6
jb
/ how to increase traction #7
Three words: Weight, Weight, Weight. BobG in Va
/ how to increase traction #8
Thanks ... I get a lot of weight from pulling 8 - 10 foot logs lifted by my 3-point. Digs the tires in pretty good. I just thought doubling my tires might be a nice touch.
thanks again ...
thanks again ...
/ how to increase traction #11
Doubling your tires will give you more flotation, and will make it more difficult to get around between trees in the woods.
If you are sinking in too much then doubling will help. If not, then more weight on your single tires will give the most traction.
Are you lifting logs now and spinning out?
I spin more with R-4 tires than I used to with Ag tires, but I like the R-4's for toughness in the woods where there are lots of stubs to poke at tires.
/ how to increase traction #12
/ how to increase traction #13
</font><font color="blue" class="small">( Hi -reason I got a compact was to pull logs from my woods. Since I cut selectively I need a smaller tractor to get around. But I would like to improve my traction , so if you have any suggestions I'd appreciate it.
thanks )</font>
Have you filled your tires? Providing you don't have marsh land or deep mud, filled tires will help almost any thing you do except mowing lawns.
If you don't have filled tires, check with a local tractor dealer, doesn't have to be a Mistubishi dealer, to see what the locals use. In your area you have to be concerned about freezing.
/ how to increase traction #14
thanks )</font>
/ how to increase traction #15
Hi fsteyer,
Don't know how much cutting you plan on, but a logging winch will allow you to stay where your traction stays good, & keep you from going in & damaging tractor or forest...
/ how to increase traction #16
Hi fsteyer,
/ how to increase traction #17
The only way to increse traction on your 2wd tractor is filling your rear tires ir rear wheel weights.
/ how to increase traction #18
2016 Ford Fusion Hybrid Sedan (A64557)
2016 Ford Fusion...
2000 Ford Windstar Van (A64557)
2000 Ford Windstar...
72'' snowblower make?
Man Basket Boom Lift Attachment (A64553)
Man Basket Boom...
2026 DEVELON DX27Z-7 EXCAVATOR (A64279)
2026 DEVELON...
17in. Bucket w/ Teeth Excavator Attachment (A64194)
17in. Bucket w/...
