How to evaluate DX24E
/ How to evaluate DX24E #1
Snowman9000
Grundy County, IL
JD 755
I'm going to see a new DX24E with FEL & MMM. I haven't paid much attention to this new model, and lift capacities or flow rates. I do care about usability of 3ph implements, ease of removing & installing FEL & MMM, ease of operation, ease of teaching a teenage operator to mow with it, etc. What would you point to as things I should notice on the DX versus the other brands? Thanks!
-don
/ How to evaluate DX24E #2
The Case hydraulics and lift capacities are right in line with the competition - a little better in some areas.
The 3ph is a true Cat 1 in width and lifts nice and high - check out how high my tiller is off the ground - can't get that with the BX series without modification. FEL removal and re-attachment is easy, like all the other quick mount/dismount loaders are. This is my first hydrostatic tractor, and man, does it make mowing worlds easier than gear drive tractors. Tranny engagement and disengagement via the foot pedal was much smoother than all 3 Kubota BX machines I test drove.
I haven't detached the mower yet, but I expect it to be the same as all the others as they all have almost exactly the same linkages. One thing the Case has that wasn't pointed out on the Kubota is that the mower deck wheels can be rotated 90* so that when you drop the deck, you just roll it out sideways - I've heard a lot of guys griping about difficulties in having to drag other 60" decks out from underneath with wheels that do not rotate, including my neighbor who owns a BX22.
The slope of the hood on the Case makes for much better visibility much closer in to the front of the machine. And the curved loader arms are really nice to work with, after only ever using machines with the dog-leg styles. Motor seems to be smoother and quieter than the Kubota.
I was able to do side by side comparisons between the Kubota BX series and the NH TZ series (twin to the Case DXE) on 2 dealer lots, and that's what made my decision easier - I went into the whole thing fully expecting to become a Kubota owner, but the Case New Holland subs changed my mind.
See pictures below.
/ How to evaluate DX24E #3
Bandit,
Love the DX24E pics -- great looking tractor. You should tell your neighbor to read his manual. The anti-scalp wheels on the BX22 MMM do pivot to roll the deck out from under the tractor.
/ How to evaluate DX24E #4
</font><font color="blue" class="small">( I'm going to see a new DX24E with FEL & MMM. I haven't paid much attention to this new model, and lift capacities or flow rates.
-don )</font>
<font color="black"> Don, I think you will find that lift capacities, hydraulic flow rates, 3pt weight capacities are all going to be fairly comparable between all similar brands. And any of the machines will probably do the job just as well as any other brand.
The deciding factors usually boil down not to functionality of 2, 3 or 4 similar units, but cost and dealer quality. I say that because the functionality of similar machines from different companies is pretty close to the same.
Some people will pick the class of machine they want, pick the trim level of features they want, and then buy the cheapest unit that meets their criteria. Others will add in dealer quality, making sure that they can get good service locally, have parts availability, and are treated well by the dealership, so they might pay a bit more for a brand that offers the added benefits of a great local dealer.
That is not to say that their are not some special advantages of some specific brands. I am an advocate of the New Holland & Farmall curved loader arms those tractors. I use a Kubota B2910 with the traditional dogleg loader arms and a TC24D with the curved loader arms and I can tell you when the 2 are compared side by side, there is absolutely no comparision the steep rake of the curved arms, combined with the sloped and curved hood design gives so much better front visibility that FEL work is faster and easier.
I'm not the most coordinated person, but I can get the FEL off of the TC24 in about 5 minutes, back on in the same amount of time. Many others do it in 2 minutes. But I will say that it is easy to take off and put back on. The TC series from NH and the DX series Farmalls use the same loaders (different colors).
I think you need to look at what tractor fits you better. You will operate a tractor safely if you are comfortable on the machine. So if you try the DX and it feels funny, the go try a different brand. Comfort is a safety factor, it is also something that will help you operate the machine more efficiently. Also look to see if the various controls seem intuitive to you. What may seem logical to me, might seem odd to you. </font>
</font><font color="blue" class="small">( <font color="black"> Don, I think you will find that lift capacities, hydraulic flow rates, 3pt weight capac )</font>
Yeah, I meant to say that I didn't care about comparing the lift capacities and flow rates. Looks like I overdid some editing there in my first post. /forums/images/graemlins/blush.gif
But I was wanting to hear your folks opinions about what you think the DX has that is better (or worse). Thanks for the posts.
-Don
/ How to evaluate DX24E #6
Anyone out there compare the DX24E to the John Deere 2210?
/ How to evaluate DX24E #7
</font><font color="blue" class="small">( Anyone out there compare the DX24E to the John Deere 2210? )</font>
You might want to look in both the New Holland Forum and the John Deere forums. There has been very little discussion about the DX24E, but the New Holland TZ series is virtually identical to the Farmall DX. The headlights are different, the paint color is different, but mechanically they are the same tractor with most/all of the same features. There has been quite a bit of discussion about the new TZ tractors and how they compare to the BX Kubotas and the mini-Deeres.
/ How to evaluate DX24E #8
Yep. And to the Kubota BX2230, and to the Massey GC2300. I chose the DX for the true Cat 1 3ph (which the 2210 and 2230 didn't have), the curved loader arms (which none of the others had), the price, the extra 2hp, and the dealers that I visited. The dealer I purchased from sells the BX2230, the NH TZ24DA, and the DX24E. The Case price fell right between the Kubota and the NH. I liked the Case color and front end better than the NH, so the lower price was icing on the cake.
I borrowed my neighbor's BX22 last Sunday because I needed the backhoe, and I realized how much I like the curved loader arms and sloped hood on the Case when I was doing some loader work with the BX. However, I was very impressed with the rear tire traction that the weight of that little backhoe gives to the BX.
/ How to evaluate DX24E #9
</font><font color="blue" class="small">( </font><font color="blueclass=small">( Anyone out there compare the DX24E to the John Deere 2210? )</font>
)</font>
I've caught some flack for being such a big advocate of the NH & Farmall curved loader arms, but it is nice to hear that someone else, who has worked the curved loader arms side by side with the old dogleg style has the same impression. It is easy to say that the old style is great, until you try the new ones!!!
By the way, I agree with you that the Farmall DX lights look better than the NH style!!! </font>
/ How to evaluate DX24E #10
</font><font color="blue" class="small">( I've caught some flack for being such a big advocate of the NH & Farmall curved loader arms, )</font>
Bob,
I think you've been vindicated. After all, not only does NH and Case have the curved loader arms, but Kioti does too now. And didn't I see where JD will have (or already has)some loaders with the curved arms too?
Seems to me that the other manufacturer's are now beginning to say what you've been saying all along. /forums/images/graemlins/smirk.gif /forums/images/graemlins/grin.gif
/ How to evaluate DX24E #11
</font><font color="blue" class="small">( </font><font color="blueclass=small">( I've caught some flack for being such a big advocate of the NH & Farmall curved loader arms, )</font>
Bob,
)</font>
Kioti does make a curved arm loader. A week or so ago I looked up the specs on the Kioti (120 & 130), the NH/Farmall (12LA & 14LA) and the Kubota (LA402). The Kioti 120, which fits a small frame CK20 is the weakest, the NH 12LA, which fits the small frame TC18/21/24 was actually as strong as the larger mid-frame sized Kubota LA402 and the NH 14LA was overwhelmingly powerful for a mid-frame size unit. My research only covered those specific loaders. So I'd say the best small tractor loader is the 12LA, for a medium frame CUT, the 14LA can't be beat. The Kioti 130 had better specs than the Kubota LA402, and I think the design is also better, but I would not think of putting that loader on the CK25 becuase at that point the loader so outclasses the tractor that the CK25 really could be eliminated from consideration as the Kioti 130 is much better matched to the CK30, which is the same physical size as the CK25 but with the larger engine.
As for the new John Deere loaders, I looked at them, and there is a thread in the JD forum. It is pretty much a bag of hot air in terms of an evolved design. They simply fell flat on their face. The lower part of the arms are actually linear with a taper, as opposed to curved, the upper arm structure is only superficially curved and the line of sight from the drivers seat to the back of the bucket, and even to the top of the bucket is STILL obscured by the loader arms. I have no idea the specs on the loaders, it could be a brute, but I hear the specs are not improved. So it was a cosmetic change and not a functional one. The JD loader arms actually curve above the top of the hood when the bucket is down. Compare that to the NH/Farmall or even Kioti, and you see the arms fall sharply toward the ground when the bucket is completely lowered which gives a nearly unobstructed view of the bucket. I will give JD credit for sloping their hood a bit more, that will help.
</font>
/ How to evaluate DX24E #12
<font color="blue">The Kioti 130 had better specs than the Kubota LA402, and I think the design is also better, but I would not think of putting that loader on the CK25 becuase at that point the loader so outclasses the tractor that the CK25 really could be eliminated from consideration as the Kioti 130 is much better matched to the CK30, which is the same physical size as the CK25 but with the larger engine.
</font>
From what I forsee the loader capabilities are based more on the hydraulics of the tractor. Both tractors have hydraulic pumps capable of 12.7 gallons per minute. Until we see some actual side by side comparisons, I believe discounting the CK25 is a bit premature.
Don
/ How to evaluate DX24E #13
Don, the reason I discount the CK25 actually has little to do with the loader. It is, in my opinion, too large and too heavy with too small an engine. JD, NH, Kubota, etc all have similarly powerful machines in a smaller package that is not pulling around the excess 1000# (and sometimes more) of weight that the CK25 has. While the CK25 might have a bit more traction due to the excess weight, I consider (again my own opinion) too heavy and too large and too underpowered. Bump it up to 30hp, as in the CK30, and it seems to be a much better size/weight/hp ratio.
On the other hand, if Kioti had put the CK25 engine into the CK20 chassis, then I would be singing a totally different tune because to me that would be another killer machine with a great size/weight/hp ratio. A small frame CK25 would be very similar to a NH TC24 or Kubota B7610. I think those are both great machines. But put that size engine in a tractor the size of TC29 or B2910 and I think it is simply underpowered, less manuverable, and overweight for the power plant.
/ How to evaluate DX24E #14
<font color="blue">It is, in my opinion, too large and too heavy with too small an engine. </font>
Bob, from my experience.....I owned a Ford 1220 HST (17hp) with a 7106 FEL. Predecessor to the TC18/21/24. I found to do any kind of serious loader work an awful lot of ballast/counter weight was an absolute necessity to achieve stability and reduce the tipsiness of the tractor. Even carrying around all the additional weight I did not find it lacking for power in my situation.
In my opinion, I see the CK25 (longer, wider more stable foot print) will more than likely, in a variety of situations, be a very productive tractor/loader combo. Certain situations, it would be beneficial, to have the extra 5 horses /forums/images/graemlins/cool.gif, then you have to weigh the extra cost of that 5 hp (because the wallet then becomes lighter /forums/images/graemlins/crazy.gif). Me personally, I'm getting to the age where I like less and less to be swinging heavy weights on and off a tractor. So, if I can get a general purpose, all around unit, with the built in weight factor, that's fine with me /forums/images/graemlins/smile.gif. If lawn compaction is an issue....I aerate the lawn every fall anyway.
The TC29 is a tweaked up TC25(predecessor of the TC29). Same engine.
As far as I'm concerned the jury is still out. I'll wait to hear some actual owner accounts.
Don
/ How to evaluate DX24E #15
Snowman,
Here's an update for you. I've now had the FEL, MMM and rear tiller on and off a few times each, and detach and attach is quick and easy on all of them. I used the instructions once for the mower to make sure I didn't miss anything, and now it's off or back on in less than 5 minutes. Same with FEL. So easy as a matter of fact, that I don't think twice if I decide to remove an implement because I think it may be in the way for a half hour.
The rear tiller is a bit more cumbersome than the other 2 when removing or re-attaching, so I'd say the 3ph implements are the most bothersome. But all-in-all, the quick attach setups nowadaysmake it a breeze to take off and put on the implements. And within a few times, you're familiar enough with the tricks to make it go that much smoother.
/ How to evaluate DX24E #16
I recently had a chance to compare Case IH DX tractors to their Kubota counterparts. The DX24E was one of the Case Models I felt had a big advantage over the Kubota. Bear in mind that this is just my opinion and i'm not out to ruffle any feathers. Here are A few of the things that I noticed:
(1) Nicer Dash with tachometer
(2) Hood tilts back to give complete access to engine compartment. The hood closes solidly and does not vibrate as much.
(3)True Cat. 1 Three Point Hitch will accept more implements.
(4) I thought the placement of the Mid PTO made it easier to connect & Disconnect the mid mower drive shaft. I have several older customers who find it difficult getting under the BX's to put on/take off the drive shaft.
(5) Increased visibility due to the sloped hood & curved boom loader design.
(6) The DX comes standard with a 36 Amp alternator. Standard charging system on a Kubota BX is only 14.5 Amps, although it is upgradeable for extra $$$$.
The good news is that you are in a no lose situation. All of the subcompacts are well designed and very dependable. Good luck with your decision! Tractorman
2016 International DuraStar 4300 Dump Truck (A64556)
2016 International...
2016 Peterbilt 579 Wet Kit T/A Day Cab Truck Tractor (A64556)
2016 Peterbilt 579...
1990 FRUEHAUF 53' DRY VAN TRAILER (A64280)
1990 FRUEHAUF 53'...
2015 Peterbilt 348 T/A 24ft Chemical Transport Flatbed Truck (A64194)
2015 Peterbilt 348...
2025 Electric Cart (A64557)
2025 Electric Cart...
Year: 2014 Make: Chevrolet Model: Equinox Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 134,356 (A64557)
Year: 2014 Make...
