How to check if starter is weak
   / How to check if starter is weak #11
"You can buy a hydrometer for about $2, which looks like an eyedropper with colored balls inside. Pull the cap off the battery, use it to suck electrolyte and make sure all the balls in the hydrometer float in each cell. The last time I was unable to start my PT422 was because the battery had a dead cell (only 1 of 4 balls floated in one cell). The unloaded voltage of the battery was 12.5V, yet it would drop to less then 9V as soon as I tried to start."
bought a hydrometer. It appears two of the cells are low or bad. The battery was purchased new from Auto zone in August of 2012. I ordered an Interstate battery with more cold cranking amps. Hopefully this helps.
Good catch, hope this helps.
I put the new Interstate battery in my 422 today. She fired right up. Couldn't believe it. You know, I checked the old battery that was bought new by the previous owner in August of 2012 with a battery load tester and it read fine. However after Tim suggested I purchase a hydrometer and check each cell, is when I found the two bad cells. I would have pulled the starter today maybe the motor too.
I really love this forum. The suggestions, tips and experiences from other members are priceless.
I feel so much better today.
Thank you all for your input.
Frank
   / How to check if starter is weak #14
That battery should still be under warranty and you should be able to get a free replacement.
Ken
   / How to check if starter is weak #15
It is my belief that if you can jump start an engine then the starter. If you cannot then it's not the battery but wiring or starter. This is a good starting point anyway. I had a rambler starter that worked fine when cold, but would not crank when hot. One of the bushings was worn and it allowed the armature to drag on the stator. Another test is to test no load current (starter removed from engine) and loaded current. These must meet the manufactures specifications.
2004 BOBCAT 331G EXCAVATOR (A52707)
2004 BOBCAT 331G...
EZ-GO Electric Golf Cart (A56469)
EZ-GO Electric...
2017 Ford Explorer AWD SUV (A55853)
2017 Ford Explorer...
2018 John Deere Z997R (A53317)
2018 John Deere...
INTERNATIONAL FLAT BED TRUCK (A52707)
INTERNATIONAL FLAT...
