Dead 1130
/ Dead 1130
Tractor started and ran a minute or so. The red wire w/ yellow stripe, (someone cut the original connector off, placed a solid red wire and connector on and electrical taped it. I had to go into the loom and verify the color). I didn't hook up is actual to the fuel shutoff solenoid. I used a jumper wire to the positive starter solenoid so I could yank it if things went wrong. Tractor started without starting fluid and ran about a minute and died. I found the hand throttle, it was frozen. WD-40 and a dead blow hammer had it working minutes later. I started 1/2 throttle. It ran a minute or so and died. Fuel shutoff solenoid was hot enough it was smoking and wire was also hot. Will have to o back down & pull fuel shutoff solenoid. The tractor is actually an 1140, 27 hp. Bad fuel shutoff solenoid tells ne that's why it died and wouldn't restart 9 years ago.
/ Dead 1130 #22
Thank you for sharing the verdict. You are a good troubleshooter. Can’t fool a man on his own stuff
/ Dead 1130 #23
If it’s a 3 wire solenoid, u might have straight wired the PULL IN wire.. that one only gets power for a few seconds to start the engine,
THEN it switches over to the other wire to “HOLD” the solenoid open..
(Black is ground)
DOOSAN G25KW GENERATOR (A58214)
DOOSAN G25KW...
Land Pride FDR1660 (A53317)
Land Pride FDR1660...
2013 FREIGHTLINER CASCADIA (A60736)
2013 FREIGHTLINER...
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A61307)
2023 Kubota...
SKID STEER ATTACHMENT MULCHER (A58214)
SKID STEER...
20.7kW Aptos 440W w/ IQ8PLUS Enphase Microinverter Solar System (A59228)
20.7kW Aptos 440W...
