How strong is steel
/ How strong is steel #1
Budweiser John
Platinum Member
Dewitt, Michigan
New Holland TC45D
I've been in the trim carpentry/building game (retired) and lumber span tables were the bible used to select lumber sizes for a particular load or span, such as floor joists.
Now having the retirement time to fabricate some labor saving goodies out of steel for storage or perhaps a boom lift for the FEL
I'm at a loss, other than gut feelings on how much (steel) and in what shapes, channel, sq. tub, angle, or pipe will support, carry or span. Yes, this the domain of the pet agreed engineering community but are there any rules of thumb or tables anywhere that would suggest for example, that a 2X2x1/4 sq. tube 6' long will support more weight evenly distributed than say a 3" channel of the same length.
I'm hoping members get the drift of my question. At this stage in the life time adventure, I'm not interested in a structural engineering degree but as a reasonably good barn yard welder with a head full of project ideas a little grass root TBN guidance is a beautiful thing.
/ How strong is steel #2
How strong is steel
No first hand knowledge here but I imagine there are some types of tables for steel that offer load resistance data for different stock...Good Luck with your query...
Something interesting I heard a long time ago...
...Not sure where this originated or if it's 100% true...but (in reference to your carpentry background) I've heard on several occasions that "pound for pound" (I guess that means dimensioned accordingly and subject to certain types of loads/forces) that #1 (clear/dense)-structural grade SYP is stronger than steel...! ?
/ How strong is steel #3
I'm an engineer and have a good friend who is a builder. He's shown me books designed for builders that whittle down months of class and pages of engineering text into the most useful basics that you are seeking. You must know how to do algebra but the knowledge you are after is out there in concise forms. Most places I've seen span tables usually have a pretty good intro/how to use the tables section that is very helpful. I suggest googling "beam equations".
The property that you most likely are after with regard to comparing two different shapes is moment of inertia (I). This is what makes a 2x8 stronger and stiffer when stood on the short edge like a joist vs on the long edge like a plank. All steel sections have this property published and it's the key input in beam calculations. You will note in the tables in the link below that there is Iy and Ix and one is larger (usually x). This is the same as joist vs plank orientations.
American Wide Flange Beams - W Beam
/ How strong is steel #4
...He's shown me books designed for builders that whittle down months of class and pages of engineering text into the most useful basics that you are seeking. You must know how to do algebra...
I'm guessing but I will go out on a limb say that if you asked a current structural engineering student...They'd say yes they had to learn the theory behind typical design calculations and all the required math-algebra/calculus etc...but these days you just type in all the variables into software programs and it spits out everything you want/need...including supplemental (after install) bracing placement etc...
/ How strong is steel #5
I've been in the trim carpentry/building game (retired) and lumber span tables were the bible used to select lumber sizes for a particular load or span, such as floor joists. Now having the retirement time to fabricate some labor saving goodies out of steel for storage or perhaps a boom lift for the FEL I'm at a loss, other than gut feelings on how much (steel) and in what shapes, channel, sq. tub, angle, or pipe will support, carry or span. Yes, this the domain of the pet agreed engineering community but are there any rules of thumb or tables anywhere that would suggest for example, that a 2X2x1/4 sq. tube 6' long will support more weight evenly distributed than say a 3" channel of the same length. I'm hoping members get the drift of my question. At this stage in the life time adventure, I'm not interested in a structural engineering degree but as a reasonably good barn yard welder with a head full of project ideas a little grass root TBN guidance is a beautiful thing.
How strong is steel? That's a huge question! Basic steel has an ultimate tensile strength of roughly 35,000 psi. (0:
You have to narrow down what questions you have for each project you are working on. Start with a simple project that only requires a few answers to be successful. Learn how to answer those questions. As you continue with more projects you will learn more and more.
There's beam formulas or table that you can use for deflection, etc.
Feel free to post pics or sketches of your design and I can provide opinion on design.
Good luck
/ How strong is steel #6
I gather you understand wood, well steel is similar.
A 2 x 8 is stiffer than a 4 x 4, well steel is similar.
Like wood trusses, steel "I" beams are best for stiffness.
When it comes to posts a square tube is better than a flat bar, just like a 2 x 4 makes a better post than a 1 x 6.
Steel will not rot but it rusts
Not realized by many but lengths of steel I beams also flex and like wood joists also need legs at intervals.
Probably the main advantages is joints can be welded and longevity is better also dimensions are lesser for same strength.
Once we made a very successful drag using wood 6 x 6's bolted together that lasted over 10 years, it was faced with 3/8 X 4" 'cutting edges'. It was later replaced with 4" angle steel similar structure. Both did an equally good job of grading our road.
The steel one was stolen for scrap value within a year but they never touched the wooden drag.
Trust the steel supplier as he will have a general good idea as to what is required for most cases.
Available are handbooks that will provide all the basic info such as PSI, etc for most dimensions available.
/ How strong is steel #7
I don't think it's quite that easy.
You can fly a plane on auto pilot but it still takes a real pilot to land. In other words you must know the theory, etc to understand the results and check for accuracy.
/ How strong is steel #8
Look for a free program called "beam boy". It has been a while since I've had a computor at home, but I remember that you could select shapes from a list, choose your length and where the loads and supports are placed, and it would give you the deflection, and peek stress amount and location.
If you have a smart phone, the App"epic FEM" is simmilar.
/ How strong is steel #9
yep,
Like plowing a field there is a lot more to it than trying to drive in a strait line.
Being a metallurgist in a previous life I would rate the question similar to
" how strong is a piece of wood"
There are over 100 grades of plain carbon steel to start with.
The ASTM Used to put out a "handbook" it was 13 thick volumes.
For a wood worker the hardest to get your mind around is wrought steel works best in tension which is opposite to timber which works best in compression.
Cast steels works best in compression.
Like timber all the tables & data sheets reffer to a "theoretical " flaw free length of steel without any nicks, scratches and bolt holes/ welds.
Weldds are castings and need to be in compression is at all possible and if that is not possible than shear.
To get the general feeling about span lengths and loads go to one of the pallet racking suppliers and look through their brochures.
Dexion for example make beams in C channel, U channel I beam & boxed beams and all of them are available in a variety of load bearing capacities.
FWIW I buy old Dexion beams which i can get for scrap prices then cut the mounting ends off.
So I know the 14' long 6 x 2 boxed beam is good for 3 ton.
It is a lot cheaper than buying new steel.
/ How strong is steel #10
Long spans with steel are difficult if you dont know the rules. I bought a portable barn from a guy that thought he would add a loft using 6in channel. The span was 24ft. The channel sagged under its own weight. The barn was only about 3 months old and i bought it for a song because he found out the hard way that what he had envisioned wouldnt work. I still havent figured out what he had in mine, the cross beams ( the thin galvanized sq tubing those carports are built with) where only held up with 1/4 in self tapping screws, even if the channel hadnt of sagged, the whole structure would have probably collasped in a good wind storm.
/ How strong is steel #11
How strong steel is like asking what beer tastes like, it all depends.
Various Steel alloys, heat treats, annealing and forging vary from steel little better than cast pot metal to the stuff that aircraft landing gear is made from. From steel that is almost a brittle as glass to steel used to make coil springs.
/ How strong is steel #12
One thing engineers would want to see first before they "calculate" any steel is the way and who made the steel. Not ALL steel is the same. Some steel manufacturer take short cuts in making of steel to save dine or two.
Just for info take a look at thus stuff. 200 times stronger than steel . 200 times stronger than steel yet lighter than paper and more flexible than a contortionist,
How This Stronger-Than-Steel Material Could Change the World
/ How strong is steel #13
There are ways to get around all the engineering. For frontend loaders and other equipment, you hunt around, taking notes from factory designs. They did all the figuring for you, no use re-inventing the wheel. After awhile you will have a general idea what works on what size tractor/FEL such as thickness of the bucket, size of the arms, etc.
If you want to put a beam in your garage to lift something, you can get ideas for that from gantry crane designs and their ratings and spans.
If you want to put steel in a structure, I stay away from that. I know it's done all the time, but if I had a major project I would need a building permit and it would have to be inspected. They would not pass any steel in the structure unless it came in a kit from the factory that way, or it had a engineer's stamp. Steel is very expensive, so I do not see the purpose of using steel in a structure unless you happen to have it laying around for free. Any steel I put in the building for lifting purposes would go in AFTER the final inspection.
/ How strong is steel #14
No way.
Ditto the Beam Boy program.
All the specs of common steel needed to calculate deflections and stresses are out there. Someone already linked it. Modulus of elasticity, distance to farthest fiber, moment of intertia, etc. etc. Beam Boy does the calcs for you. But for simple designs (point load, or evenly distributed loads) it really isnt difficult to calculate long hand.
Formulas are actually the same for wood. You are just using different material. Thus it has different modulus of elasticity (wood varys but is ~1.0-1.2 million) and steel that is 30 million. (what that number represents is how many pounds of force it takes to stretch 1 square inch of material to double its length.
That modulus is used to calculate the Moment of inertia. Which in laymans terms is stiffness or resistance to bending. With alot higher modulus of elasticity, steel calculates to a much higher moment of inertia.
Your earlier inquiry about common things like "what is stronger, a 3" channel or a 2" sq tube. That is something that you can simply look at the Moment of inertia (i4) and whichever is higher is stiffer. No need to actually plug numbers into a formula.
/ How strong is steel #15
Ill call BS here. They are probably talking very fine fiber strength and comparing to bulk lo strength steel. Fine drawn music wire has a tensile in the 600,000 psi range. ... And the fine drawn steel wire/fiber is still HUGE wrt graphene fiber. Theres a lot more to the story than that deceptive headline.
/ How strong is steel #16
Not at all.
Steel is made to specifications, these are used to perform any calculations. Tensile strength, yield strength, hardness, weldability and machinability, etc.
It doesn't matter who makes it or "how it's made"... any calculations and specs will go quite simply off those numbers.
/ How strong is steel #17
Actually it is that easy...As I said: learning theories is part of being an engineer but doing physical calculations with a slide rule or even a scientific calculator or need to interpolate printed tables etc...It has gone by the way side...w/ computer technology...!
...And planes can land on their own with advanced ILS systems...as long as there is someone to enter the variables like passenger/cargo and fuel weight etc...all ground and weather conditions along with navigation guidance that interfaces with the avionics/autopilot and part of the ILS system...
Actually I think it could very well be true...you have to relate the words "pound for pound"...and of course the application is in play...but...say you took a piece of #1 SGD SYP lattice or a 2x4 or a dowel say...and a piece of regular (new) steel that was the same length but weighed the same as the SYP...seems to me that in certain load conditions the wood could support more load (in some conditions, way more) without failing or permanently deflecting than the steel "dimensionally proportioned to make weight"...which reminds me of an interesting factoid...
...Designing any type of load resistance...one of the factors is the "modulus of elasticity" of the material to be used...(FWIW) The "MoE" of a material is a property that defines how much said material can deflect (under load) yet return to its original shape...It might come as a surprise to some that regular plate glass is close if not at the top of the list for being "truly elastic"...
/ How strong is steel #18
Lots of good info here. For more, I suggest the OP pick up a book on "Mechanics of Materials" for some fun reading/learning in his retirement. They cover beam and column formula derivations (basic calculus/algebra) and then tie that into material properties. The book will be loaded with all sorts of tables, charts, and formulas. With that book, I can pretty much design anything in any material, but it's particularly useful for structural steel since it will have tables for all the standard size I beams, W beams, etc... That is probably the single most used book I still keep around from college. May be the only one I still use regularly, and it's most often used for stuff outside of my job, such as home projects, hobbies, etc.
/ How strong is steel #19
In reply to what I think is your original question... Franklin2 has the answer... Looking at existing similar equipment will give you a very good idea of what size / shape of metal to use... if in doubt, go a little to the heavier side for extra strength.... 90% (or more) of home built equipment is done this way and they work fine... remember KISS...(keep it simple...s...)
There are ways to get around all the engineering. For front end loaders and other equipment, you hunt around, taking notes from factory designs. They did all the figuring for you, no use re-inventing the wheel. After awhile you will have a general idea what works on what size tractor/FEL such as thickness of the bucket, size of the arms, etc.
/ How strong is steel #20
I think what you need is to design in wood then change it to steel.
Ignore all the other steels. A36 is what you'll get at the steel supplier. Its mild steel. Mild steel does not heat treat or do anything funny.
Sounds lke you need someone to give you steel tube, channel, I-beam equivalents of 2x4s, 2x6s, 2x8, 4x6, 4x8, etc and that can be done.
