How old a tractor would you go if you require a front end loader?
   / How old a tractor would you go if you require a front end loader? #41
My place is on the side of a mountain... We have nothing but 2WD, and old... Amazingly, none of the equipment has slid to the bottom of the mountain to be abandoned because we can't drive it around regardless of the weather being wet, or icy.
Yes, 4WD would be nice, but seriously, it isn't the end of the world without it. Heck, I'd love a cab too, but sun, rain or snow, the open station machines continue to run, and do what needs to be done.
As a fellow hill-dweller, I understand what you're saying. But if doing any heavy loader work with a machine on any sort of grade, I'd still stay away from 2wd. Simply put, you have no brakes on the front wheels of a 2wd machine, and the rear can sometimes get too light to provide braking traction when there's a load in the bucket and you need to traverse a hill.
With a 4wd machine, the fronts are always engaged with the rears, such that braking applied to the rear wheels still has an effect on the front. With the transmission engaged, you have an inability to go freewheeling down the hill on the fronts, when the rears get too light to maintain traction.
It's nice to think that we can always back down hills, to keep maximum weight on the rear, but I routinely find myself in situations where that's just not always practical.
So, while I have no huge bias on age of the machine, I would insist it's 4wd and has power steering. I've owned a 4wd manual steering machine with a loader, and trust me, it's a good way to develop elbow joint problems!
   / How old a tractor would you go if you require a front end loader? #42
There are several versions of the 5610: 5610, 5610II and 5610S
The 5610S is the newest, solid blue and New Holland decals, "S" on the radiator side panels. It was a very basic 2wd, 8x2 manual trans 70 PTO HP tractor. (The older ones had a smaller engine and 62 PTO HP, but could have manual shuttle, 4wd, factory cab etc.)
Almost any tractor mechanic could work on that, simple tractor.
4wd is not an absolute need, does make the job easier if you are on soft or slippery ground.
I run both 2wd and 4wd utility size loader tractors. Both can do the same work really, but the 4wd can always do it easily, the 2wd requires weather planning (wet/dry) and additional ballast/chains at times.
Personally I'd go no older than 1980s to ensure you get a full hydraulic loader (down pressure and hyd bucket) The tractor wearing the loader is much nicer with power steering, and differential lock.
Basic manual trans works, but is tiring using it for hours on end day after day, especially if non shuttle and a center shift model with limited reverse speeds. I've done many days work with manual trans loader.
No question a modern model with powershuttle or hydrostatic and 4wd is way nicer to use. Depends on what you want to spend!
Another reason why I snagged a Yanmar YM2610 with the PowerShift aka PowerShuttle. I had a JD850 being gear. At the end of the day the left leg was SORE from all the clutch work. The YM2610 is basically the JD850 with PowerShift. What a life saver !
I can add a loader for it. Loaders are just very pricey right now, even used.
   / How old a tractor would you go if you require a front end loader? #43
IMO must have's are power steering and wide front wheel spacing, the rest are nice options but most likely for limited use of the loader you will not regret saving the money.
very little time without power steering and a fel will make you cuss the tractor and decision.
narrow front end and you may not get the chance to cuss your decision.
   / How old a tractor would you go if you require a front end loader? #44
Can be done with 2wd, but 4 is nicer. 20+years ago
about the same time frame
again 2wd can do it
But much nicer and almost enjoyable, 2014-2015 time frame
when the front and rear blades were on and she's plugged in and warm.
Definitely much nicer it was -7F outside that morning
   / How old a tractor would you go if you require a front end loader? #45
I think Budget was mentioned earlier.
If the Op can swing it, I would also agree- Get MFWD, power steering, obviously a wide axle. minimum of 30 HP, and a live PTO if not independent PTO. With at least a weight of 4000 lb with the FEL
If funds are limited I would rather have a 1965~ or newer 2 wheel drive utility tractor with FEL than a 2000lb 4x4 small CUT with FEL but that is jmo. IF in hilly country probably do need to start with MFWD but I would not buy one that did not already have a FEL on it.
This is somewhat like muscle cars,
Speed costs Money- How Fast do You want to Go?
   / How old a tractor would you go if you require a front end loader? #46
I'd buy a skid loader or a wheel loader.
   / How old a tractor would you go if you require a front end loader? #47
It's been about ten years since I was shopping the older used tractor market, but at least back then and around here, older tractors were free with an FEL. What I mean by that is that you could buy an FEL for $4k, or you could buy one with a tractor attached for not much more. Buying an old tractor, and then shopping for an FEL to fit it appeared to be an expensive and frustrating way to go.
   / How old a tractor would you go if you require a front end loader? #48
I have a 2WD 1970's David Brown 990 with a Case/DB 56L loader,great outfit,very well built loader.Also have a 1973 Oliver 1365 4WD with loader does a good job.
   / How old a tractor would you go if you require a front end loader? #49
I once used a tractor loader from early Ford style. Not sure of the model maybe the loader was a 771. When the bucket was flat on the ground it didn’t curl back, you had to push into the pile and raise loader to get back angle. Useless.
Then I bought my first loader an Oliver 770. 60s machine? The loader was pretty strong and curled back well. Big clumsy machine but $2600. I rebuilt the backhoe and it served me well. As business was getting bigger and faster I bought a new 1985 JCB turbo with a 4 in1 bucket, good machine too pricey for your usage. Then I bought a used Case 750 loader, good loader but they came out with a wet brake model in 1986 855d Cummins powered, loader ripper. Now thats a serious loader. But again pricey. I also bought a Case W-20 wheel loader 2.5 yd bucket. Too pricey again. Now retired I sold all those and many others and got some different ones to keep on my property. I think the Ford 445A I have might be a good fit for you. Got it for $6500 with a Gannon box on the back. Needed some work but it’s fine for here. I also have a JCB 1550 B and that’s a good loader, and a 1975 MF400 loader/ripper which I have shown on this forum as I restore it. Very serious loader.
   / How old a tractor would you go if you require a front end loader? #50
1969 4020 with 48 loader or do you need to be older than that?View attachment 772368
This is about twice the horsepower you mentioned but this 4020 will work any new row crop tractor to the ground and not break a sweat, It has little brothers in the same series with hp you mentioned.
(2) 55 GALLON DRUMS OF WINDSHIELD WASHER FLUID (A58376)
(2) 55 GALLON...
2022 John Deere 4052M MFWD Compact Utility Tractor with 400E loader - Bucket, Forks and Grapple (A55314)
2022 John Deere...
HYD QUICK ATTACH STUMP GRINDER (A52706)
HYD QUICK ATTACH...
1993 International Navistar 4900 DT 466 (A57148)
1993 International...
12 X 20 CAR PORT (A58214)
12 X 20 CAR PORT...
2014 PETERBILT 384 TANDEM AXLE CDL REQUIRED WRECKER (A59575)
2014 PETERBILT 384...
