Oil & Fuel How much oil ???
/ How much oil ??? #21
could be they changed the pan (or whole engine) design part way through the model year.
and plenty of people only pull 1 plug. If you expect to see 1 plug, you don't keep on looking after you find 1, but I think I've always got them both.
/ How much oil ??? #22
Yes I did take out both drain plugs. I thought I mentioned that I had previously
owned a kubota L 4200 some years back and it had the same divided oil pan.
I don't understand why a Kubota mechanic would say there was two different
pans and the manual does not . Or how this little motor could trap the 1 1/2
to 2 qts. of oil up in it.
There has got to be some other explanation for what they say it
holds ? Later
Ok thanks for replying to us, Well I don't have a good explanation then for why the difference in qty's of oil.. Unless the manual is wrong. I know that my new Kioti manual is wrong on several things, for it contradicts itself in several places. And the service manual and owners manual have some discrepancies.
James K0UA
/ How much oil ??? #23
Are all Kubota dip sticks the same?
Maybe the stick or the tube is the wrong one?
/ How much oil ???
just bill ;
I ask that same question bill, and was assured that that wasn't possible !!
how they know this for sure i don't know.
I have sent the Kubota corp. an email with these questions but have not
received an answer as of this date, 5/16/12.
/ How much oil ??? #25
Sure seems odd to be that far off.
I have 3 Kubotas and all are very close to the specified amounts.
CASE INTERNATIONAL 5240 TRACTOR (A63291)
CASE INTERNATIONAL...
2013 Chevrolet 3500 Dually (A62613)
2013 Chevrolet...
2015 CanAm Commander 800 BRP Side by Side (A62613)
2015 CanAm...
Rotary 15,000lb. 4-Post Auto Lift (A64556)
Rotary 15,000lb...
2022 SANY SY50U EXCAVATOR (A63276)
2022 SANY SY50U...
2016 Freightliner 108SD 26Yd. Side Loader Garbage Truck (A64194)
2016 Freightliner...
