how much does sod weigh?
/ how much does sod weigh? #1
JiminGa
Platinum Member
I'm trying to figure out just what my next tractor should be. I currently have a 2305 and I know I can't lift a pallet of sod with it...so, what compact will lift a pallet of sod? I figure that's probably the heaviest thing I'll ever lift.
thanks
/ how much does sod weigh? #2
I always try to judge weight by looking at something in cubic metres. 1 cubic metre is roughly 1000kg. (I know things have different density and weight and all that but thats my rule of thumb for general guess work)
My utility trailer has a level capacity of 2.5 cubic metres. When I get a trailer full of sand it is nearly always around 2500kg nett weight. A trailer full of 1/2in graded gravel is about 1800kg and a trailer of 4in graded stones is about 1300kg...
Sorry I think metric...... now.....in ft/inches/pounds... I'll guess your pallet of sod is fresh damp sod, probably 3ft high, 3 ft wide, 3 ft deep? Ball park numbers I'll guess about ~1.2 tons.......
Like the guy said in the movie JAWS....I think we'll need a bigger boat.... (but in your case a tractor).....lol
TBH... if you get the sod delivered regularly, you should get onto the supplier to find out exactly how much a pallet weighs, rather than guessing??? They will have the numbers for vehicle loading weights...
/ how much does sod weigh? #3
Depending on how wet it is, a pallet of sod weighs between 2000 and 3000 lbs
HEAVY.
/ how much does sod weigh? #4
A relatively dry pallet of St Augustine will weigh at least 1600# 40x48 pallet stacked 5' high. A really wet pallet would add a few hundred #.
thanks, sounds like I'll need one h*^l of a tractor to move those around much.
/ how much does sod weigh? #6
thanks
How about half loading the skids.
/ how much does sod weigh? #7
Here's the numbers from 'deskref' book by Glover
3375 lbs/cubic yard -earth, dense
2106 lbs/cubic yard -earth, loam dry, excavated
2430 lbs/cubic yard -earth, moist, excavated
2565 lbs/cubic yard -earth, packed
2916 lbs/cubic yard -earth, soft loose mud
2700 lbs/cubic yard -earth, wet, excavated
RIDGID AIR COMPRESSOR (A65643)
RIDGID AIR...
2020 GMC AT4 CREW CAB TRUCK (A65054)
2020 GMC AT4 CREW...
iDrive TDS-2010H...
2018 CATERPILLAR 320GC EXCAVATOR (A60429)
2018 CATERPILLAR...
2017 FREIGHTLINER CASCADIA 6X2 T/A SLEEPER TRUCK TRACTOR (A59910)
2017 FREIGHTLINER...
2020 ISUZU NRR 4X2 S/A 22FT BOX TRUCK (A59912)
2020 ISUZU NRR 4X2...
