how much does sod weigh?
/ how much does sod weigh? #1
JiminGa
Platinum Member
I'm trying to figure out just what my next tractor should be. I currently have a 2305 and I know I can't lift a pallet of sod with it...so, what compact will lift a pallet of sod? I figure that's probably the heaviest thing I'll ever lift.
thanks
/ how much does sod weigh? #2
I always try to judge weight by looking at something in cubic metres. 1 cubic metre is roughly 1000kg. (I know things have different density and weight and all that but thats my rule of thumb for general guess work)
My utility trailer has a level capacity of 2.5 cubic metres. When I get a trailer full of sand it is nearly always around 2500kg nett weight. A trailer full of 1/2in graded gravel is about 1800kg and a trailer of 4in graded stones is about 1300kg...
Sorry I think metric...... now.....in ft/inches/pounds... I'll guess your pallet of sod is fresh damp sod, probably 3ft high, 3 ft wide, 3 ft deep? Ball park numbers I'll guess about ~1.2 tons.......
Like the guy said in the movie JAWS....I think we'll need a bigger boat.... (but in your case a tractor).....lol
TBH... if you get the sod delivered regularly, you should get onto the supplier to find out exactly how much a pallet weighs, rather than guessing??? They will have the numbers for vehicle loading weights...
/ how much does sod weigh? #3
Depending on how wet it is, a pallet of sod weighs between 2000 and 3000 lbs
HEAVY.
/ how much does sod weigh? #4
A relatively dry pallet of St Augustine will weigh at least 1600# 40x48 pallet stacked 5' high. A really wet pallet would add a few hundred #.
thanks, sounds like I'll need one h*^l of a tractor to move those around much.
/ how much does sod weigh? #6
thanks
How about half loading the skids.
/ how much does sod weigh? #7
Here's the numbers from 'deskref' book by Glover
3375 lbs/cubic yard -earth, dense
2106 lbs/cubic yard -earth, loam dry, excavated
2430 lbs/cubic yard -earth, moist, excavated
2565 lbs/cubic yard -earth, packed
2916 lbs/cubic yard -earth, soft loose mud
2700 lbs/cubic yard -earth, wet, excavated
Caterpillar TH255C Forklift (A63688)
Caterpillar TH255C...
John Deere 4840 Tractor (A66285)
John Deere 4840...
New Holland 3930 (A60462)
New Holland 3930...
1995 Freightliner FLD120 Tandem Dump (A62613)
1995 Freightliner...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61573)
2021 Mercedes-Benz...
New/Unused Wolverine 3 Point Hitch Attachment (A65583)
New/Unused...
