How much am I pulling?
/ How much am I pulling? #1
Turfman
South Weber Utah
Kubota B2710
Just trying to figure how much weight I'm pulling with a full 60" Land Pride box blade. With a 60" width, 17" high moldboard and a bucket depth of 22" I figure the bucket has a capacity of about 12-13 cubic feet. Nearly a half yard. At about 2700-3000 lbs per yard of soil, that makes a weight of around 1300 lbs in the box. Am I figuring this correctly?
/ How much am I pulling? #2
yup, assuming the box is completely full, which is unlikely. I would think that friction and the effects of (more or less)shearing the soild at the blade would add a lot more to the load from the tractors' perspective.
/ How much am I pulling? #3
I think you are overestimating the weight of a yard of material. Nominally, a cy of dirt should weight about 2000lbs, give or take for moisture. A yard of 3-4kpsi concrete is going to be closer to the 3k# figure, again, give or take.
A mechanical engineer will be better able to comment on the weight carried, and apparent load at the blade, friction coefecient, etc, etc.
Soundguy
<font color=blue>"Just trying to figure how much weight I'm pulling with a full 60" Land Pride box blade. With a 60" width, 17" high moldboard and a bucket depth of 22" I figure the bucket has a capacity of about 12-13 cubic feet. Nearly a half yard. At about 2700-3000 lbs per yard of soil, that makes a weight of around 1300 lbs in the box. Am I figuring this correctly? "
/ How much am I pulling? #4
<font color=blue>A mechanical engineer will be better able to comment on the weight carried, and apparent load at the blade, friction coefecient, etc, etc</font color=blue>
I'm a mechanical engineer. Here is the result of my detailed analysis.
You are pulling much more than you could without the tractor /w3tcompact/icons/grin.gif
/ How much am I pulling? #5
See... I knew someone would step in. What was the old joke people always used to tell me?.. Ok.. What is the difference between a civil engineer, and a mechanical engineer? Civil eng's build targets.. mechanical eng's build the toys to use on the targets.
Guess I better go start building some targets....
Soundguy
<font color=blue> mechanical engineer will be better able to comment on the weight carried, and apparent load at the blade, friction coefecient, etc, etc
<font color=red>I'm a mechanical engineer. Here is the result of my detailed analysis.
/ How much am I pulling? #6
Here is the real answer to your question. I've calculated a theoretical drawbar pull for your tractor. I've made a few assumptions:
1. After all the losses in the driveline, You get 20 HP to the wheels. (optomistic)
2. You have enough traction to use all 20 HP (also optomistic)
3. I'm assuming a 100:1 gear reduction
You can go about 4mph in low gear, & your rear tire is about 4 feet in diameter
4mi/hour*hour/60min*5280ft/mi = 352ft/min
4ft*pi=12.6ft/rev
(352ft/min)/12.6ft/rev = 28rev/min wheel speed
engine 2800rev/min / 28 rev/min = 100:1
Torque calculation
20HP * 550 Ft-LB/sec = 11000 ft-lb/sec
11000 ft-lb/sec * min/2800 rev * 60 sec/min = 235 ft-lb per rev
235 ft-lb/rev * 100:1 gear reduction = 23500 ft-lb/rev
23,500 ft-lb/ 2 ft radius = 11,750 pounds drawbar pull!
Consider this a maximum, It is optomistic, I could be off by a factor of 3 +/-
I took an educated guess at your gear ratio, it may be off.
Like I said before, much more than you could pull without the tractor /w3tcompact/icons/grin.gif
/ How much am I pulling? #7
The local mobile home dealer made a special 3pt. mobile home toter. What it is, is a dolley that supports the tounge weight of the mobile home on a swivel with two small wheels. From the dolley is a 5' bar that attatches to the back of the tractor via a 2" receiver. ( looks like the modified or made a beefy standard trailer dolley, then modified it to be tractor powered. )
Anyway, they move those mobile homes with a big case/ih.. older model. I saw them moving one the other day.. was only going like 2-3 mph.. but id didn't look like there were any problems. Amazing what you can pull with gear reduction, sufficient traction, leverage, and a rolling load.
Soundguy
<font color=red>"Consider this a maximum, It is optomistic, I could be off by a factor of 3 +/-
Like I said before, much more than you could pull without the tractor "
/ How much am I pulling? #8
<font color=blue>Amazing what you can pull with gear reduction, sufficient traction, leverage, and a rolling load.</font color=blue>
I pulled a mobile home up a slight grade with a my 36hp Long/Landtrac, just put it in low and used the diff-lock till I got it rolling. Pulled it right up to the pad with no problems.
New/Unused Wolverine 78in Quick Attach Land Leveler (A65583)
New/Unused...
FIFTH WHEEL PLATE AND MOUNT (A65643)
FIFTH WHEEL PLATE...
3ft Metal Jeep Tailgate (A65583)
3ft Metal Jeep...
(1) 30 Yard Roll Off Dumpster (A65579)
(1) 30 Yard Roll...
(4) Heavy-Duty Pipe Gates (A66408)
(4) Heavy-Duty...
New 4400lb All Steel Adjustable Gantry Crane (A62679)
New 4400lb All...
