How many hours can you expect on a gas engine Power Trac?
   / How many hours can you expect on a gas engine Power Trac? #11
Maybe not necessary but it would last longer and burn less fuel.
Get some prices on name brand 25hp 3600 rpm diesel engines that will fit in the same footprint. Let's see how the prices compare. It would be interesting. My 2001 25hp Kohler burns just about 1 gallon per hour at full throttle. Diesel costs 12% more than gas right now. So we'd have to figure that in as well.
my 4 cyl Kubota generator 10kw burns 1/2 gal hour at moderate load.
   / How many hours can you expect on a gas engine Power Trac? #13
There’s no need to run 3500 rpm if it was designed not to to start with. I never claimed the upfront cost was less. Not running at 3600 rpm would lead to longer pump and engine life.
   / How many hours can you expect on a gas engine Power Trac? #14
The pumps have to turn at 3600 rpm to get the proper flow and pressure. They're direct mounted to the engine. If the engine can't turn 3600rpm, then you're going to have to add pulleys and belts, or gears to drive them, or use different, more expensive pumps that can get the flow and pressure at lower rpms, etc.... all adding cost.
   / How many hours can you expect on a gas engine Power Trac? #15
Not if it was designed to run slower to start with. I agree a diesel repower would be a nightmare.
To start with it would be good to get one of those cheap tachometes to see what the actual engine rpms are when you are working under a heavy load. It may be down as low as 2600 rpm anyways. Some of the air cooled emissions diesels are higher rpm. but any repower is very difficult.
   / How many hours can you expect on a gas engine Power Trac? #17
What I'm getting at is you'd have to do a lot of re-engineering to get a 25hp diesel engine, three pumps, fuel tank, battery, hydraulic cooler, air cleaner, exhaust system squeezed into the tub of a PT400 series chassis, and keep the cost the same as a gas powered PT425. I don't think you can, over the lifetime of the machine, break even on the added cost of the diesel engine and different pumps, even if you could get them to fit into the tub.
With the average small tractor owner putting only about 50 hours per year on a machine, a 2000 hour gas engine will last 40 years. Chances are you'll be dead before it wears out. More likely the hoses or pumps or wheel motors will fail way before the engine does.
   / How many hours can you expect on a gas engine Power Trac? #18
Any time I hear the engine RPMS change while working, I just let off the foot pedal enough to get the sound back to normal. It's intuitive after just a couple hours of operation. Doesn't matter if its mowing, brush cutting, loader work, climbing steep hills, etc.... you just operate these things by your senses. Kinda like flying stick and rudder seat of the pants. Full throttle all the time. Listen for changes. Your feet adjust the directional speed automatically. It's a thing of beauty.
   / How many hours can you expect on a gas engine Power Trac? #19
On my 422 I changed the engine out at 2,924 hours on it. Could have had it repaired but I had another 22 hp engine I bought years ago as a spare so I just put it in. I don't run it at full rpm's I just run engine speed at what is needed, using mini hoe fast idle , mowing probably 3/4 throttle and just running around or using loader just what I feel is needed. My ground is very hilly going up hill half to full throttle depending on slope going down hill slow idle speed. I will admit I do not change oil and filters at 50 hours more like 100 hours, I believe changing oil depends a lot on what conditions tractor is used for.
   / How many hours can you expect on a gas engine Power Trac? #20
I used to frequent another website focused on commercial mowing and those guys were getting up to 4000 hours on a Kohler 25 HP horizontal engine. At the time, the horizontal engine (like the one in the PT) was MUCH more durable than a vertical Kohler engine. I have one in my Exmark and the oil stays remarkable clean due to the heavy duty air filter. If I were to guess, I'd say a heavy duty air filter (Donaldson type) will make the most difference in longevity, other things being equal. You'd be surprised to know how much dust gets past any air filter (read an interesting article on this subject once).
I'm also a fan of using synthetic or synthetic blend oil in air cooler engines due to its ability to maintain stability and viscosity at much higher temps than conventional oil. Also, I'd recommend Shell Rotella Diesel oil due to it's high levels of Zinc (1200 ppm). The amount of Zinc, an important anti-wear additive than protects the engine on cold startups, has been significantly reduced in most "gasoline motor oil" for emission reasons.
Freighliner Tender Truck (A56436)
Freighliner Tender...
40 (A52708)
40 (A52708)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2008 Bobcat S250 Compact Wheel Loader Skid Steer (A59228)
2008 Bobcat S250...
1996 International Semi (A59814)
1996 International...
*Selling at Royal Auction Zephyrhills, FL Location* (A59230)
*Selling at Royal...
