GT2550 Kohler engine, valve train noise
   / GT2550 Kohler engine, valve train noise #11
Randy certainly knows as he repairs them for a living. Me. I just own 2 Kohlers, besides the commode in the bathroom....:D
One opposed twin 'Command Series' gas guzzler on the wife's zero turn and an ancient but stone reliable K series on my engine drive welder that I've never had any issues with other than required maintenance, oil changes, air filter renew and a spark plug in the last 25+ years.
I do like the sound of the K series engines produce when idling.
Actually that opposed twin Kohler would be either a KT series or a Magnum not the Command which is V-twin OHV. But you are right, nothing will replace the K series.
   / GT2550 Kohler engine, valve train noise #12
Randy.. I mis spoke. I forgot I did have to replace ONE component on mine, the non adjustable carb. My Lincoln engine drive welder has the auto idle on it and when I bought it many, many years ago, the engine would not pick up from an idle cleanly not matter what I tried so I replaced the carb with an adjustable idle and high speed jet and that cured that issue. Since then, just normal maintenance and I use the welder a lot. It's skid mounted and goes in the back of the truck. Great unit for field work and being an older one, it's a transformer unit not IGBT so nothing to fail inside. Just started using it for powering the arc gouging torch which really requires a transformer unit as a solid state IGBT welder cannot handle the inetermittent amp load well. I have replaced the starting battery a few times as well even though I try to keep it on a battery tender when not in use. I'll own it until I exist no more.
No other engine I know of produces that distinct sound when idling. Kind of musical in a way...
   / GT2550 Kohler engine, valve train noise #13
Kind of that long stroke loppy sound
Mini Skid-Steer Hydraulic Root Rake Grapple (New/Unused) (A59225)
Mini Skid-Steer...
2021 ASV RT-120F FORESTRY SKID STEER (A52709)
2021 ASV RT-120F...
2014 FREIGHTLINER CASCADIA (A58214)
2014 FREIGHTLINER...
1765 (A58375)
1765 (A58375)
Rainbow Self-Propelled Volume Gun (A53317)
Rainbow...
BUSH HOG 8 SHREDDER (A58216)
BUSH HOG 8...
