GT2550 Kohler engine, valve train noise
   / GT2550 Kohler engine, valve train noise #11
Randy certainly knows as he repairs them for a living. Me. I just own 2 Kohlers, besides the commode in the bathroom....:D
One opposed twin 'Command Series' gas guzzler on the wife's zero turn and an ancient but stone reliable K series on my engine drive welder that I've never had any issues with other than required maintenance, oil changes, air filter renew and a spark plug in the last 25+ years.
I do like the sound of the K series engines produce when idling.
Actually that opposed twin Kohler would be either a KT series or a Magnum not the Command which is V-twin OHV. But you are right, nothing will replace the K series.
   / GT2550 Kohler engine, valve train noise #12
Randy.. I mis spoke. I forgot I did have to replace ONE component on mine, the non adjustable carb. My Lincoln engine drive welder has the auto idle on it and when I bought it many, many years ago, the engine would not pick up from an idle cleanly not matter what I tried so I replaced the carb with an adjustable idle and high speed jet and that cured that issue. Since then, just normal maintenance and I use the welder a lot. It's skid mounted and goes in the back of the truck. Great unit for field work and being an older one, it's a transformer unit not IGBT so nothing to fail inside. Just started using it for powering the arc gouging torch which really requires a transformer unit as a solid state IGBT welder cannot handle the inetermittent amp load well. I have replaced the starting battery a few times as well even though I try to keep it on a battery tender when not in use. I'll own it until I exist no more.
No other engine I know of produces that distinct sound when idling. Kind of musical in a way...
   / GT2550 Kohler engine, valve train noise #13
Kind of that long stroke loppy sound
2021 Chevrolet Tahoe SUV (A56859)
2021 Chevrolet...
SKID STEER ATTACHMENT CEMENT MIXER (A58214)
SKID STEER...
2024 DIGMASTER MINI EXCAVATOR (A58216)
2024 DIGMASTER...
1998 Homemade S/A 12x6.5ft Trailer (A56859)
1998 Homemade S/A...
2015 CASE 621F WHEEL LOADER (A58216)
2015 CASE 621F...
Truck Metal Cargo Storage Box (A55788)
Truck Metal Cargo...
