How long before Compact Diesels are obsolete?
   / How long before Compact Diesels are obsolete? #101
The original Ford built tractor, commonly described as a Fordson, has steel wheels!
Your 1964 Ford tractor has steel wheels?
No, but the serial tag says Fordson. Fordson tractors were built from 1917 thru 1964.
   / How long before Compact Diesels are obsolete? #102
I think that the tractor you have is called a "Fordson Major".
A very different animal.
The tractors simply refrred to as "Fordsons" were last built in 1928.
   / How long before Compact Diesels are obsolete? #105
I thought Major is a model name, not a brand name.
   / How long before Compact Diesels are obsolete? #106
Tractor models[edit]
Fordson Model F
Fordson Model N
Fordson All-Around (also called Fordson Row Crop)
Fordson Major E27N
Fordson New Major
Fordson Dexta
Fordson Power Major
Fordson Super Major (called the Ford 5000 in U.S.)
Fordson Super Dexta (called the Ford 2000 Diesel in U.S.)
   / How long before Compact Diesels are obsolete? #108
Diesel ICE tractors aren’t going anywhere. The battery technology isn’t there and it probably never will be. Diesel fuel is over 13 times more energy efficient than the best lithium ion batteries by volume and over 50 times more efficient by weight. And batteries aren’t sources of energy, they’re storage devices for energy that comes from somewhere else.
I’m not sure why people think that battery technology improves at the same rate as other technologies. It doesn’t. A space efficient and energy dense battery that could match the energy potential of a tank of diesel is the holy grail of science and it hasn’t been invented yet and it probably never will be, unless you want a nuclear powered tractor.
A battery powered tractor that doesn’t get used much may be more applicable than a battery powered car, but when people are dropping tens of thousands of dollars on a machine they want convenience and capability. A diesel tractor can do quick jobs or bush hog a 50 acre field if necessary. With a battery powered tractor you’ll spend more money for less capability and convenience, not happening in the minds of most common sense people.
YouTube
   / How long before Compact Diesels are obsolete? #109
YouTube
I agree. Battery powered will never happen. A Quantum leap is required into something more efficient such as your suggested Nuclear Powered tractor.
   / How long before Compact Diesels are obsolete? #110
Can you imagine what havoc could be had by rodents in a modern electric vehicle, and what would happen if a battery went to ground after a particularly healthy meal by said rodent?
2019 RAM 5500 Bucket Truck with Versalift VST47 Boom - Cummins Diesel - 4X4 - Automatic (A56435)
2019 RAM 5500...
2017 Mitsubishi Outlander SUV (A56859)
2017 Mitsubishi...
2015 Ford F550 Bucket Truck - Altec AT40M Boom - Powerstroke Diesel - Automatic Transmission - 4X4 (A55302)
2015 Ford F550...
Blue Diamond 103709 (A53317)
Blue Diamond...
2017 JOHN DEERE 437E KNUCKLE BOOM LOADER (A52705)
2017 JOHN DEERE...
2022 FREIGHTLINER CASCADIA SLEEPER (A56129)
2022 FREIGHTLINER...
