Tractor Sizing How important is rear diff lock on CUT?
/ How important is rear diff lock on CUT? #1
onelostdogg
PA
EX3200
New to tractors. looking for something 25-30HP for plowing snow, working in the woods, moving dirt, etc. 8 acres on north side of a fairly steep ridge. Looking at a Yanmar 424 since dealer is only 5 miles away, but from everything I've read, there is no locker on the rear axle. Is this a deal breaker?
Thanks for your opinions.
John
/ How important is rear diff lock on CUT? #2
Without it... you can be stuck. I have not used it much but it's darn handy to have to get you out of sticky places.
That's what I was thinking. When I'm in the woods, my Polaris 700 spends most of it's time in 4WD. Wasn't sure if I could cheat by working myself out with the loader or not? I guess always better to have it and not need it.
/ How important is rear diff lock on CUT? #4
Do you have good split brakes? And can access them while moving forward? If so, you can do as well by slightly braking the spinning wheel. I use this technique more than the locker most of the time. But it is easy to do with the brakes on the left and hydro pedals on the right.
I need to check into that. Not sure if the 424 has split brakes or not. Thanks.
/ How important is rear diff lock on CUT? #6
I just used mine for the first time today , wet lawn , slope , and bare wet clay . Its worth having
/ How important is rear diff lock on CUT? #7
I have it and use it when going up muddy hills. Even with four wheel drive and front loader. Saves on tearing up the turf.
/ How important is rear diff lock on CUT? #8
Personally, I wouldn't buy a tractor without a dif lock!
SR
/ How important is rear diff lock on CUT? #9
/ How important is rear diff lock on CUT? #10
Having both is best. If you had to do without one it would preferably be the diff lock. Split brakes are more versatile. If it has neither dont buy it.
larry
/ How important is rear diff lock on CUT? #11
Just curious. When did diff. locks become standard on tractors?
I graduated from HS and left the farm in 1965. My memory isn't that good, but I don't remember any of the tractors that I drove as a kid (e.g., my Dad's AC G and WD45, my uncle's Farmall H and M, etc.) having diff. locks.
Steve
/ How important is rear diff lock on CUT? #12
No diff lock on '62 JD 2010.
/ How important is rear diff lock on CUT? #13
larry
I would tend to agree. I could get by without the diffy lock, but it is handy too sometimes to engage just before you hit the mud to maybe prevent "being detained" in the first place, where the split braking of the moving wheel only works after traction is broken, and this allows you to try gain forward momentum again. But if it has neither.. pass.
/ How important is rear diff lock on CUT? #14
Steve
They didn't. you just braked the spinning wheel. Of course their prime function was as turning brakes to shorten turns when plowing in soft ground.
/ How important is rear diff lock on CUT? #15
If the tractor is 4WD you will probably not need a diff lock too much. It does come in handy once in a while. I use it some when I plow snow or when I need all the tractor I can get like if I am pushing a tree out. Like James said you can use split brakes to change what wheel is putting the power down.
/ How important is rear diff lock on CUT? #16
The old ones didn't have it and people would use the split breaks if they lost traction.
On the other hand I thought all modern tractors had diff lock. You don't use it often but it can get you going again. So I would say it's handy but you have to judge if it's a deal breaker. For me it is.
/ How important is rear diff lock on CUT? #17
I must admit that I don't use mine that much, however when I get stuck I get stuck and am glad that I do have it. My Kubota has front and rear differential lock which is great. The downside is that your tires have to be pointed straight ahead or you will break gears.
/ How important is rear diff lock on CUT? #18
My advice would be; buy everything you need and a few things you want the first time. Then there is no second time. Driving a little further to a different dealer is worth it.
/ How important is rear diff lock on CUT? #19
Can't find a good picture of the left side of the operator's station anywhere but it looks like it only has one brake pedal.
/ How important is rear diff lock on CUT? #20
Whenever you are on uneven ground, and one wheel starts to spin, you're stuck. Diff lock gets you out. I have 4wd and have to use my diff-lock often. Split brakes are OK too, but they help you go, by "stopping" which sucks power, and sometimes you have one chance to get out without digging a hole and don't want ANYTHING holding you back. The difflock gives you forward motion without ever holding back.
I would NOT buy a tractor without diff-lock, unless you are saving boatloads of $$$. Such a simple problem causes all work to stop, and adds a new problem. Stuck tractor.
2020 VERMEER LP873SD1 VAC-TRON VACUUM TRAILER (A63276)
2020 VERMEER...
2025 Hydraulic Brush Cutter Skid Steer Attachment (A61572)
2025 Hydraulic...
John Deere 8245R (A64119)
John Deere 8245R...
2024 GD Yatian LY05A Model T Replica Electric Cart (A61574)
2024 GD Yatian...
2020 International LT625 Sleeper 48" (A62613)
2020 International...
UNUSED WOLVERINE 3PT QUICK HITCH RECEIVER (A64281)
UNUSED WOLVERINE...
