Tractor Sizing How important is rear diff lock on CUT?
/ How important is rear diff lock on CUT? #41
If you get stuck- either you are reallllllly stuck or the diff lock is nice feature to get out smoothly and quicker. On the other hand if you are moving something on grass/dirt and one side is spinning and if you dont want to spin tires for less disturbance, I would just engage the lock. no problemo.
I love mine when I want it, but I probably could do without it if I had no choice.
/ How important is rear diff lock on CUT? #42
:laughing: Sounds like the problem exists between the steering wheel and the seat back. Perhaps the operator headspace and timing needs adjustment.
I got a laugh out of your reply as the first thing that came to mind after your post was my friend Mike who has buried just about every piece of equipment he has ever owned in something he could have easily avoided. It seems we could line up 3 pieces of any equipment at the edge of the same field and 2 of us would always end up going back to pull him out of something that we just drove right threw or around but he would find a way to get stuck in it. He actually got our D9 stuck once which is something I thought next to impossible! By the way its not an easy thing to get out once its buried!
/ How important is rear diff lock on CUT? #43
A stuck D9? OMG what ever did you get to get it out with? Worst I've seen is a D7 buried to the foot pedals. That took another D7 and a two yard excavator to ease it out of the mud.
Machines don't get stuck "operators get stuck" myself included.
Old Hee Hah joke : Doc I broke my arm in three places!! Well stay out of them places.:)
/ How important is rear diff lock on CUT? #44
I too want to know, How the heck do you get a D9 stuck???? And then How the heck do you get it out?????
On the diff lock. I've only had to use it a few times, but on all of them it was the difference between getting the job done and not getting the job done, even with FWD and in LO with high RPMs. I would never buy a tractor without. Fortunately every tractor I've ever looked at has it standard, including the yanmars I looked at.
/ How important is rear diff lock on CUT? #45
D9s don't have much for flotation.
https://www.youtube.com/watch?v=OpF2XJZh_GU
Notice the soldier standing in the most dangerous place when they tighten up the cable!!
/ How important is rear diff lock on CUT? #46
I looked at the 424 also, I bought a kubota b2620 instead,
I got it stuck the first 10 minutes I had it in a snow bank, a little off kilter and one front tire and one rear tire would spin. I hit the diff lock pedal and backed right out. I thought to myself "man I'm glad I didn't buy the Yanmar!"
/ How important is rear diff lock on CUT? #47
Hey you didn't post the picture so it NEVAH Happened! :)
Even if I had thought about a photo, It would have been a bit hard to get off the tractor and back on. The tractor has 3 steps up on the mounting ladder, the first one about 18" off the ground, which puts the operator platform at armpit height on flat ground and with it (the mounting steps) being centered on the ditch which was about 2 feet deep, I would have needed a step ladder to get back inside, assuming I wanted to put my 66 year old bones into a 3-4 foot jump into a muddy ditch filled with rocks.
/ How important is rear diff lock on CUT? #48
Be my luck to jump down and land by a big snake that was PO'd that I just ran over his tail with the front tire.:eek:
/ How important is rear diff lock on CUT? #49
Whenever you are on uneven ground, and one wheel starts to spin, you're stuck. Diff lock gets you out. I have 4wd and have to use my diff-lock often. Split brakes are OK too, but they help you go, by "stopping" which sucks power, and sometimes you have one chance to get out without digging a hole and don't want ANYTHING holding you back. The difflock gives you forward motion without ever holding back.
I would NOT buy a tractor without diff-lock, unless you are saving boatloads of $$$. Such a simple problem causes all work to stop, and adds a new problem. Stuck tractor.
Actually split brakes suck power, but dont necessarily hold you back. Used just enuf, which is dependent on familiarity, they will give you all the forward thrust a diff lock can while simultaneously augmenting the ability to steer. This is especially important in slippery side sloped conditions.
larry
/ How important is rear diff lock on CUT? #50
I have a diff loc. Almost never use it. Too much of a PITA to try to hit it with the heal. Which requires setting the hand throttle instead of using the pedal. (gear tractor). I use split brakes much more.
Diff loc wont keep an angled rear blade from pulling you sideways. Split brakes will. That is what I use them for the most. With 4wd and r1 tires, diff loc dont add much help at all in the muck IMO
/ How important is rear diff lock on CUT? #51
I would not want to use the split brakes all the time where the diff lock will do the job. The diff lock doesn't add any extra wear to the gears while the brake shoes have a definite wear out time. If you used the left brake all the time to aid in plowing you'r going to wear out that sides brakes needlessly.
/ How important is rear diff lock on CUT? #52
And it would be a huge power waste if you had to do more than touch them occasionally.
/ How important is rear diff lock on CUT? #53
The key to using them is a light touch goes a long way. I could not push the snow off of my sloped driveway without them. The tractor wants to go downhill. But a little touch on the uphill brake and you can maintain your line of travel. It is all about practice.
/ How important is rear diff lock on CUT? #54
I'm actually the perfect example of how you're wrong there. I have R1s, 4WD, and a very heavy (for its class) tractor. As I said before, when I needed the diff lock, I really needed it, both in snow and mud. Of course with an HST, I don't have foot throttle to worry about, but one of the times I needed the diff lock was on my neighbors PST JD. Heel on the diff lock, foot on the clutch, hand on wheel, hand on throttle. I was spinning 3 tires, hit the differential lock, and just powered on through.
/ How important is rear diff lock on CUT? #55
I agree there. I was really wishing the split brakes on the CK were actually usable this winter. I spent soooo much time pushing snow banks back with the angled back blade skidding side ways down the driveway. Really Kioti, why do you even bother to split the brakes when you can't use them. I think split brakes (usable ones) and differential lock should be standard on every tractor.
/ How important is rear diff lock on CUT? #56
You see the brakes on the hydro DK's are on the left. Pretty dang handy.
/ How important is rear diff lock on CUT? #57
WHy were they not useable? The split brake on my DK works just fine!
/ How important is rear diff lock on CUT? #58
Why were they not useable? The split brake on my DK works just fine!
The CK brakes are on the same side (right)as the HST pedal. Not a problem on a gear, but I have not yet mastered the skill of pushing both the HST pedal backwards and the brake forward:laughing: Also, the little latch that holds them together has defeated me on how to get it to unfasten.
On the DK, the HST brakes are on the left, and easy to split, making them very useful.
But let's not hijack the thread, I've ranted elsewhere about this issue.
/ How important is rear diff lock on CUT? #59
CK's are on the right . OK for gear, not OK for hydro trans.
/ How important is rear diff lock on CUT? #60
Where is my head at? That's right your brakes are on the wrong side just like some of the Kubota tractors I looked at.
86 (A63290)
86 (A63290)
John Deere BW17029 Tractor Bucket (A65640)
John Deere BW17029...
New/Unused ATS Mini Excavator (A65583)
New/Unused ATS...
2005 DRAGON END DUMP TRAILER (A65643)
2005 DRAGON END...
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
2018 Generac S/A Towable Light Tower (A64194)
2018 Generac S/A...
