Tractor Sizing How important is rear diff lock on CUT?
/ How important is rear diff lock on CUT? #81
My older tractors never had a diff lock. When we purchased the 655A it has 4wd and a diff lock. I love the diff lock on that ford! When looking for a newer tractor I didn't need the front wheel assist so much but a diff lock was very important to me.
/ How important is rear diff lock on CUT? #82
Someone should do a test on the diff lock. See how much a tractor will pull then see how much it will with the diff locked.
/ How important is rear diff lock on CUT? #83
What?, actual scientific evidence? I, dunno...:)
/ How important is rear diff lock on CUT? #84
Not real scientific bu thave done it. I was chained to stump try to it out. One rear & one front spinning and digging holes, stopped and engaged dif lock when I start wheel motion again tractor tried to come over backwards & I was hooked to the actual draw bar not the 3pt. Dif lock does work but my HST pedal is on same side as breaks so couldn't use brakes and didn't even think of it.
/ How important is rear diff lock on CUT? #85
Do competition pulling tractors use posi rear ends?
/ How important is rear diff lock on CUT? #86
I was going to mention that. I don't think they do. If they did they would not be able to steer with the brakes.
/ How important is rear diff lock on CUT? #87
It would be a deal breaker for me...My JD2305 has a lock and I use it a lot....snow blower....loader work...must have
/ How important is rear diff lock on CUT? #88
Well I just learned that I have a diff lock on my little Ford 1210, don't remember seeing it in the manual but it is there:laughing: Also my old International Cub has a locking lever to lock to power to the left, right or both wheels, at least when it would stay in detent:confused:
/ How important is rear diff lock on CUT? #89
This back tip is a special case ... climbing out of a hole while pulling is very dangerous because the traction point shifts forward of the rear axle and has more leverage on lifting the front.
/ How important is rear diff lock on CUT? #90
If you got 2wd and no diff lock, you only have 1wd
If you got 4wd and no diff lock, you only have 2wd
I use my diff lock most when moving dirt/gravel. Helps me push deeper into pile.
Wrong.
2wd is 2wd even if one wheel is spinning. The non spinning wheel will be trying to propel the tractor with the exact same forward force as the spinning wheel is.
Same with 4wd.
The reason I find the diff loc dont do much, is cause if traction between the two tires is near equal, it wont do much. Now if you drop a front in a blow hole and one of the rears unloads or is in the air, yea it will get you out. Or if one tire is hung in a mucky ditch and the other on solid ground, it will help. But so will split brakes in both cases.
Its certainly not a fact. With an open diff, both wheels are driving with equal force. THAT is a FACT.
If one wheel happens to have significantly less traction (in the air, on ice, etc) then the wheel with good traction can ONLY deliver an equal amount of force as the wheel with lesser traction.
It seems you understand how lockers and open diffs work. So lets not perpetuate the false terminology by saying 1wd.
Go get yourself cross axled and tell me how many wheels are spinning..
In 2wd you will have 1
In 4wd you will have 2
And the ones that aren't spinning, are trying to drive the vehicle with the exact same force as the ones that are spinning.
The number of wheels spinning has nothing to do with how many are trying to drive.
LD1, I had a "knocking your head on the keyboard" icon for this type of case. I gotta try to find it.
larry
/ How important is rear diff lock on CUT? #91
The differential lock saved me this weekend. Despite knowing it was too muddy, I just couldn't resist the urge to get out the tractor since the sun was finally shining, and thought I'd move some of the firewood that we cut last year but never moved to the wood shed. I did get stuck trying to get back up a small hill and my tire dug a rut before I even knew it happened. Differential lock was all I needed, and once both tires had traction, off I went. It's funny, but when I felt my tire slip the first time I IMMEDIATELY thought about this thread. :)
/ How important is rear diff lock on CUT? #92
larry
The one into the brick wall works :mur:
/ How important is rear diff lock on CUT? #93
you still have two wheel drive. ld1 is right about that.
however, ld1, when one tire is spinning and the other isn't, the non spinning tire cannot be receiving the same torque as the spinning one. that would be effectively locked. if the non spinning tire was receiving the same torque, the spinning tire would never have started spinning.
in spinning, the tire has lost its resistance (to the ground). so the torque follows the path of least resistance. and, youre stuck.
in braking the spinning tire with its brake only, you are fooling the rear end into thinking the tire has regained its resistance. (it has, actually. just with the brake shoes and not with the ground). but the rear end doesn't know the difference. so it begins to equal out the torque delivered. ie, it now gives torque to the non spinning tire. this is shown by slightly braking the spinning tire; the tractor eases off. lock, or nearly lock, the spinning tire with its brake; the tractor moves away more suddenly, because more torque was transferred.
when equal resistance (grip) is felt on the tires, equal torque is given to each tire. 2 wheel drive, c4ranch.
imo, split brakes are much more usable than a diff lock. sort of an adjustable diff lock. except, of course, for the power loss caused by braking.
/ How important is rear diff lock on CUT? #94
To each his own. I still maintain that if traction is similar (and barring unusual circumstances it usually is close) that the locker don't add much help when pushing a pile.
yes, I have to agree. if traction is equal, I don't see how a diff lock can do anything extra.
/ How important is rear diff lock on CUT? #95
Wrong. The torque is equal even if one wheel is spinning. You are still applying the same torque to the non spinning tire.
You can apply torque but not have movement.
When braking the spinning tire, it takes more torque to spin it. Since torque is split equally, that means more torque goes to the non spinning tire that has better traction. And hopefully get you out of the mud.
Open diff is equal torque and unequal speed
Locker is equal speed, unequal torque
/ How important is rear diff lock on CUT? #96
if it were equal torque all the time, then never would only one tire spin.
they would both spin. this is not the case.
I see what you mean, though. the overall torque is only what the spinning tire can use? which isn't much if its spinning.
maybe it is always equal. Ive always looked at it as not.
when braking the spinning tire, you put the resistance back. that's for sure. so what youre saying is the overall torque then goes back up equally? sufficient now to move the vehicle with the good tire?
with a hard brake on the spinning wheel, perhaps youre not so much transferring more, as you are increasing it more (vs a light brake pedal) overall?
makes sense that way too.
a diff lock should always tear grass with the inside tire. a well practiced split brake application will not.
/ How important is rear diff lock on CUT? #97
No worries fellas. When you climb out of your tractor simulators I'll buy ya a beer.
Not sure I've ever had any real experience where traction is equal. One tire always seems to spin before the other. This equal traction sounds more in theory than real life. If ya got the engine turning only 1 wheel, that's 1wd in my book. But you can debate all u want.
More people on this thread seem to know the value of a locker from experience.
Flame on.
/ How important is rear diff lock on CUT? #98
If one tire is on ice and one on dry pavement, it takes less torque to spin the tire on ice.
Let's say it takes 50 ft lbs to move the tractor. But only 25 to spin the tire on ice. BOTH tires will see 25 ft lbs, but only one will spin, and the tractor won't move.
Apply the brake now to the tire on ice. It now takes 75 ft lbs to spin it. In turn, the other tire will also see 75 and the tractor will move.
You are forgetting, you don't need movement (spinning tire) to have torque. The non moving tire does get the same torque as the spinning one.
/ How important is rear diff lock on CUT? #99
Torque. Traction. Think a little more.
,,,larry
/ How important is rear diff lock on CUT? #100
While it is true the torque in an open differential is always equally distributed the thing to keep in mind is the torque delivered is limited to the amount that will not make the tires slip. If one tire is up in the air it takes very little torque to make it spin; therefore, very little torque is being applied to the non-spinning wheel also. Equal torque to each wheel, but very little torque. Hence, you aren't going to get much forward movement. When neither tire loses traction then you get the maximum torque the drive train is capable of producing.
2022 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A64556)
2022 Peterbilt 567...
2017 Ford Escape SUV (A64557)
2017 Ford Escape...
LAND PRIDE 10' HYD 6 WAY BLADE (A64278)
LAND PRIDE 10' HYD...
(INOP) 2022 MACK MD6 WATER TRUCK (A64280)
(INOP) 2022 MACK...
JMR 72in Dual Cylinder Grapple Rake Skid Steer Attachment (A64553)
JMR 72in Dual...
1985 GREAT DANE 45' SLIDE AXLE FLATBED TRAILER (A59911)
1985 GREAT DANE...
