How does an HST compare in pulling power with the same tractor and a gear trans?
   / How does an HST compare in pulling power with the same tractor and a gear trans? #251
More controllable torque delivery yes, but as you go into adding ballast and counterweight, loader and a loader load you fairly promptly encounter situations where you cant apply enough torque to the wheels to move - even in low range. The relief valve in the HST just opens and youve got to find a work around to proceed. Typically the max wheel torque deliverable from a comparable gear tractor is much higher. I find that ~ 2nd or 3rd gear of an 8 speed will exceed the torque limit of a 3 range HST.
I've never had a problem.
   / How does an HST compare in pulling power with the same tractor and a gear trans? #253
That endorsement would apply to Commercial Class C only. I’ve had those endorsements when I had a commercial License Class B for busses. They have Commercial Class C with Passenger endorsements for vans. Fairly sure on this but I could be wrong.
A have a class A but I have a 5th wheel restriction because I took the test in my dump truck. If your testing vehicle doesn’t have a manual transmission and air brakes you get those restrictions as well.
   / How does an HST compare in pulling power with the same tractor and a gear trans? #254
Ah ok.
Mine currently just says A-Comb / M-Motorcycle.
No restrictions or Endorsements.
I have heard that new applicants if testing without air brakes or manual trans will get automatic and air brake restrictions, but I haven’t actually seen it.
   / How does an HST compare in pulling power with the same tractor and a gear trans? #255
The results of this thread so far; Those who love geared transmissions still love them. Those who love HST's still love them. And some of us could live quite happily with either. Pretty much exactly the same results as before the thread was started.:)
   / How does an HST compare in pulling power with the same tractor and a gear trans? #256
Bingo! 😂
   / How does an HST compare in pulling power with the same tractor and a gear trans? #257
I'll say it again, HST work best for some jobs but loose some HP to inefficiency. Geared trannies work better for other jobs and loose very little HP. Neither are prefect but both have there place.
   / How does an HST compare in pulling power with the same tractor and a gear trans? #258
HP is rarely a factor when trying to see how much something can drawbar pull. Weight and traction are. If HP is your limiting factor, you are in the wrong gear or range(HST).
I can spin all the tires in low range on a HST. A gear tractor can do the same. So two tractors, same weight, same tires, both capable of spinning tires....I fail to see how one will outpull the other. When you already cannot get ALL the power to the ground.....loosing a little due to HST losses is irrelevant.
When it matters is trying to pull something at a specific speed.....like trying to pull a disc at 6mph and up a slight hill. If you struggle to maintain speed with a HST, then the gear version of the same tractor WILL do better.
But the notion that a gear tractor can pull significantly more.....or in the case of the messicks video (which was terrible BTW) claiming that the gear can pull 50% more.
Sure, that may be true in high range....but who pulls in high range?
I pull a 3-14 plow with my HST MX5100. By that notion I should be able to pull a 4-14 or a 4-16 easily had I opted for the GST trans.
   / How does an HST compare in pulling power with the same tractor and a gear trans? #259
I think this is 100% accurate ... Its a good perspective. I have many hours of moldboard plowing and pulling disk with my tractor and yes you are right I never ran out of power I only ran out of power at a certain speed... I find the low range is too slow and the mid range is not strong enough while I pull something. Since I got my tractor I have been saying, its not strong enough, but really it is, its just too slow. I have said, I should've bought a gear tractor to get the extra few HP on the PTO but I have said more often I should've bought a bigger tractor which the last one is the real issue ...
I just find I would have more speed selection for the strength required with a gear traction. but maybe I am wrong about that since I haven't tested it.
   / How does an HST compare in pulling power with the same tractor and a gear trans? #260
If Kubota had made a Hydro in the size of tractor I require, I would have probably bought it but they don't, so I didn't. HST's are inherently easier to operate than a gear drive tractor, especially for a gal, or at least that is the case with my wife.
2018 MACK GU813 DUMP TRUCK (A59823)
2018 MACK GU813...
SUV (A59231)
SUV (A59231)
Pace American MW8516TA2 T/A Enclosed Concession Trailer (A56857)
Pace American...
2019 Chevrolet Silverado 1500 Pickup Truck (A55973)
2019 Chevrolet...
2009 Bruton T/A Enclosed Livestock Trailer (A55973)
2009 Bruton T/A...
New/Unused Electric Golf Cart (A57453)
New/Unused...
