2 Wheel Tractors - Buying & Using
   / 2 Wheel Tractors - Buying & Using #221
Hi 955,
It depends on the model.
A solid axle machine (715, 725, 710, 730, 718, 722, G85, etc.) is a bear, especially with larger tires or wheel extensions. In tight areas, you'll end up going forward and backward a few times. There's a cheat - poor mans differential - but you can't use them to till.
A differential machine (735, 745, 737, 605, 850, 853, 107d, etc.) is easy peasy. You simply unlock the differential and spin it. If you're in a higher gear and you grab one brake, it'll spin faster'n you can!
   / 2 Wheel Tractors - Buying & Using #222
FarmerboyBill is correct, my 853 spins around faster than I can walk when I squeeze a wheel brake lever and make a 180 degree turn. The individual wheel brakes are sometimes all I use when mowing as I make quick brake inputs to make small changes in the tractor direction. It is easily and less effort than steering with the handlebars.
Bill in NC
   / 2 Wheel Tractors - Buying & Using #223
I would like to see a non differential bcs mowing and turning with the free wheel adapter. I wonder how difficult it would be to turn.
   / 2 Wheel Tractors - Buying & Using #224
Stumbled across this thread yesterday and just finished reading it. (A guy has to work sometime). What a great thread. Shame it stopped way back in 2011.
   / 2 Wheel Tractors - Buying & Using #225
Hi! I like walk behind! Here we have two kinds. One is without differential as Troy-Bilt Horse BCS 710-720 etc... And Bcs Grillo etc with differential and lock.
But They are one other. Walk behind without differential with steering clutch. Then asian walk behind ( 600 lbs) Kubota and Yanmar make very good ones. Steering clutch work very well (As on bulldozer) for turn or drive.When you press one hand lever you free the wheel (no power) Other wheel turn at same speed as before No two more fast as with differential and with brake we spill energy. And If we press two hand levers we stop the tractor and PTO is running as a Live PTO.
Agria makes 3400KL without differential with steering clutch.
I dont know if we can buy walk behind with steering clutch here in America.
Happy New Year ! Oldmech
   / 2 Wheel Tractors - Buying & Using #227
Very possible to be 15K,,,, Gravely tried marketing rebadged Rapids and the larger models were close to that price if I remember correctly. Keep in mind that most of these machines with reasonable use and care will last beyond their original purchaser,,, most are truely buy once and your done machines.
   / 2 Wheel Tractors - Buying & Using #228
Hi TimberXX :)
Here is a link to a German internet-page with some more pictures of the tractor in question:
Gebrauchte Traktoren und Landmaschinen
Agria 2-wheel tractors are very well built but also very expensive, and therefore mostly used by professional users.
As I read the advert, you will get the Agria 3400 KL with a tiller and a power harrow for the price mentioned. Using the following German internet-pages, I have tried to evaluate the price:
Agria Einachsschlepper 3400 Diesel Schnellgang (Grundger舩) - MotorLand.net - Europas gr?ter Motorger舩e-Shop
Agria Anbau-Kreiselegge K 90 - MotorLand.net - Europas gr?ter Motorger舩e-Shop
Agria 3400 diesel: €8079.- ($11,031.-)
80 cm (31.5") tiller: €4789.- ($6,539.-)
90 cm (35") power harrow: €3529.- ($4,818.-)
This adds up to some $22,388.- incl. 19% German VAT (or $18,813.- without VAT), but still $2,868.- more than the price asked in the Machinio-advert.
This is still way above my budget, but as js5020 rightly points out, you are probably not buying an Agria for yourself, but for your children or even grandchildren. I see very few new Agrias in use here in Germany, but the older ones are very popular in the vintage-tractor scene and among private owners. Here you will easily see more than 50-year-old Agrias in original conditions running just fine, and most will probably even outlive their owners!
Rapid is a Swiss-made brand for the professional user, mostly seen in the alpine region of Central-Europe.
Best regards
Jens
   / 2 Wheel Tractors - Buying & Using #229
Its unfortunate that the pricing structure is what it is with 2 wheel machines compared to ride on machines (similar), and in my situation I mainly just mow grass and remove some snow, I dont need equip for gardening as I do raised beds, both tasks are well within the capabilities of any "semi" modern 2 wheeler but mowing 4 acres with one every week or two is more than I want to do. I thought long and hard on a new BCS but ended up not buying due to the amount and frequency of mowing.
   / 2 Wheel Tractors - Buying & Using #230
The rebadged rapids were nice because they had Hydrostatic trannys, which is a great feature. But they priced themselves out of the market when you can buy a kubota bx1860 for $9k.
Wagon Wheel Rocking Chairs (A55758)
Wagon Wheel...
1998 PETERBILT 377 MIDROOF SLEEPER (A58214)
1998 PETERBILT 377...
CAT 289D3 (A58214)
CAT 289D3 (A58214)
Teakwood 3 Tier Stand (A57454)
Teakwood 3 Tier...
New/Unused CFG Industrial MX12RX Mini Excavator (A57453)
New/Unused CFG...
2017 Mitsubishi Mirage G4 Sedan (A56859)
2017 Mitsubishi...
