How do you carry your chainsaw ?
   / How do you carry your chainsaw ? #21
I would suggest NOT just putting it in your bucket. It is theoretically possible that the saw could bounce out and get run over by the tractor. Theoretically....
JayC
   / How do you carry your chainsaw ? #22
I drive over rough land. I've bent a new bar holding the saw by the bar such as Stewie's setup. I imagain on smooth land though, it works well.
   / How do you carry your chainsaw ? #23
Yes it can and does happen I bounced a O45AV Stihl out of my truck while backing out of a rough area and ran over it. I felt rather foolish and poor after the repair parts bill.
   / How do you carry your chainsaw ? #24
I put a sleeve on the side of my weight box for the saw, gas, oil & tools in the top of the box.
   / How do you carry your chainsaw ? #25
Were you using a Kolpin Press like his when you bent the bar? The reason I ask is because the power head rests on a padded support plate so it is hard to understand what forces would cause the bending.
   / How do you carry your chainsaw ? #26
I was afraid of bending my bar due to the ground I usually operate on so I created this setup. While its not pretty it secures the saw and I don't worry about bending the bar.
   / How do you carry your chainsaw ? #27
What whacked the saw head to bend the bar? I have the Kolpin bracket on my ATV and a homemade slip bracket in the carryall of the tractor if the bar bends from the weight of the saw head bouncing around under any conditions I'm thinking that the saw head is way too heavy :eek: I too have some pretty rough land (livestock has to graze in pairs so one can lift the rock while the other feeds) and I don't worry about the saw bracket after having it that way for about eight years -- JMHO
   / How do you carry your chainsaw ? #28
No. Just a homemade holster that held just the bar. If the device supports the powerhead also, there shouldn't be a problem.
   / How do you carry your chainsaw ? #30
Here's mine all from scrap... The plastic bar cover was part of a case that the local hardware store lost so they gave me the other half for free. The bottom of the bar cover was cut out to avoid water /debris accumulation. The assembly mounts with a single 5/16" bolt and "clamps" around the splash guard 1" steel pipe on the tractor.
chainsaw mount 1-20120707-1917.jpgchainsaw mount populated 20120708-1731.jpg
MURRAY PUSH MOWER (A55745)
MURRAY PUSH MOWER...
UNUSED FUTURE HYD HEDGE TRIMMER (A52706)
UNUSED FUTURE HYD...
2011 DOOSAN G25KW GENERATOR (A55745)
2011 DOOSAN G25KW...
2014 Ford Taurus Sedan (A56859)
2014 Ford Taurus...
2017 FREIGHTLINER CORONADO SD122 DAY CAB (A56138)
2017 FREIGHTLINER...
2017 Chevrolet Ambulance (A55973)
2017 Chevrolet...
