how do replace link arm balls
/ how do replace link arm balls #1
porkster
I see some of the farm equipment suppliers have the replacement link arm balls. They seem to carry the weld on and just the ball. How do you go about replacing just the ball? I have cat 2 arms and would like to put cat 1 balls in so I don't have to use bushings on cat 1 implements.
/ how do replace link arm balls #2
Think you may have to use the weld ons. The ball rotates in what appears to be a pressure formed socket.
Egon
/ how do replace link arm balls #3
You cut the ends off of your arms and weld the new ends on. Or, have you thought about tack welding the sleeves in you balls? There is another way. You could change the pins on the implements to a Cat. 1, if you don't have many implements.
/ how do replace link arm balls #4
Another suggestion that others don't always like is forget about the sleeves. We have Cat 1 implements that have been used for 25 years on Cat 2 3 point with no sleeves.
Only difference is a little easier to hook up.
The hay rake, tedder, spreader, wood splitter, and bush hog are all cat 1. The only Cat 2 we have is the snowblower.
/ how do replace link arm balls #5
Some cat 2 tractors actually have replaceble sockets.. so you can swap ball sizes. For the others.. you just weld a new end on it.
As others said.. sleaves work fine too.
Soundguy
2022 C&W Gooseneck Trailer (A64047)
2022 C&W Gooseneck...
2016 Ford F-350 Pickup Truck (A61568)
2016 Ford F-350...
2010 International 4300 Truck Altec DM47TR Insulated Material Handling Digger Derrick Truck (A64194)
2010 International...
2013 John Deere 8360RT Track Tractor (A63109)
2013 John Deere...
2016 MACK CXU613 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2016 MACK CXU613...
8x5 Cattle Panel Gate (A64047)
8x5 Cattle Panel...
