How do I stop shearing bolts?
/ How do I stop shearing bolts? #1
agood
Kubota L2900
I am using a small 4' bush hog and I keep shearing off the 1/2 bolt that holds the PTO shaft to the gear box on the mower. As long as I am cutting weeds and grass, it does fine but as soon as I hit some small woody plants for trees, it shears off. I did not have this problem when I used this mower behind my B7500....I guess becuase it did not have the HP to shear the bolt......
So what kind of bolt should I use...???
Thanks
/ How do I stop shearing bolts? #2
I recommend get rid of the sheer bolts and add a slip clutch.
/ How do I stop shearing bolts? #3
You can change to a higher-grade bolt. Are you using the specified grade bolt now or a softer one? Just make sure the bolt you use is always the weakest link. If not the bush hog gearbox or the tractor PTO drive will break first. /forums/images/graemlins/frown.gif
/ How do I stop shearing bolts? #4
The bolt is the fuse that prevents damage to the cutter; mainly the pto shaft and the gearbox. I don't recomend changing to a harder bolt as it may cause damage to the mechanical bits and the deck itself.
/ How do I stop shearing bolts? #5
I would agree unless he is using a softer bolt than it was designed for. I had a mower deck that was designed to use a Grade 8 - ¼” bolt. I’m sure using a Grade 2 bolt it would have sheared much more often than necessary to protect the gearbox.
/ How do I stop shearing bolts? #6
My last post wasn't written well. I meant that he shouldn't use a harder bolt than called for by the manufacter. Sorry for any confusion.
I have and my cutter paid the price.
</font><font color="blue" class="small">( I recommend get rid of the sheer bolts and add a slip clutch. )</font>
Where would I get one of these? Does it have to be specific to the manfuacturer of the cutter or do they make a generic one? Is there a place online I can order it?
/ How do I stop shearing bolts? #8
agood,
I'm taking a long shot here but one difference between tractors that may affect the shear pin is a quicker clutch engagement. It takes a lot more torque to wind up that blade suddenly and it may weaken your pin.
Are you using the same PTO shaft?
John
/ How do I stop shearing bolts? #9
Are you engaging the PTO at just above idle and then ramping up the RPMs, or are you slamming the mower into action at full RPMs, The latter will waekon the shear.
I have only ever lost one in 5 years.
/ How do I stop shearing bolts? #10
How big are these "small woody plants" you are cutting? I wouldn't try to cut anything bigger than 1" with a 4' cutter, and if you have multiple pto speeds, use the lowest, (540 rpm). Usually an operator will figure he can cut anything the tractor can knock down, but that would be assuming a 5 or 6' cutter for your tractor. Tractor Supply Co., or most any place that sells tractor supplies will have a slip clutch for around $100.
</font><font color="blue" class="small">( Are you engaging the PTO at just above idle and then ramping up the RPMs, or are you slamming the mower into action at full RPMs, The latter will waekon the shear.
I have only ever lost one in 5 years. )</font>
I never engage the PTO at any speed other than idle.
</font><font color="blue" class="small">( agood,
John )</font>
Everything is the same as was connected to the B7500.
</font><font color="blue" class="small">( How big are these "small woody plants" you are cutting? I wouldn't try to cut anything bigger than 1" with a 4' cutter, and if you have multiple pto speeds, use the lowest, (540 rpm). Usually an operator will figure he can cut anything the tractor can knock down, but that would be assuming a 5 or 6' cutter for your tractor. Tractor Supply Co., or most any place that sells tractor supplies will have a slip clutch for around $100. )</font>
I could easily cut 2" trees with it connected to the B7500....But I would usually back over the tree slowly......and let it chip away at the tree.....but I never ever sheared a bolt......the 1st time I connected to the L2900....I was cutting a friends pasture and it sheared when I hit a small rotten stump.....hit alot more than that with the B7500 and never had it shear.
/ How do I stop shearing bolts? #14
</font><font color="blue" class="small">( do they make a generic one? Is there a place online I can order it? )</font>
Slip Clutch on Ebay
If you think you'd like to order online instead of talking to your tractor dealer, I'd suggest Corriher who advertises on TBN or check out the clutch currently on Ebay. These clutches are generic and if you go to a different cutter you can take the clutch with you. For the type of problem you are having, I think this is your best solution.
/ How do I stop shearing bolts? #15
AGri-Supply sells slip clutches for about $56 that will fit on your 4' bush hog, you will have to adjust the clutch to your liking
Gosh, They want $92 for the one on ebay and AGRI-SUPPLY only wants $56. The pictures look identical....am I missing something....is one better than the other?
/ How do I stop shearing bolts? #17
</font><font color="blue" class="small">( They want $92 for the one on ebay and AGRI-SUPPLY only wants $56. )</font>
Not everything on Ebay is a good deal. /forums/images/graemlins/tongue.gif I was referring you to that posting so you would know what you are looking for more than anything. Have you checked with your local dealer? This is a common item, so many places will carry it. Tractor Supply Company has them also, but since your profile doesn't list your location, I can't be sure if you have Tractor Supply Stores in your area.
/ How do I stop shearing bolts? #18
A slip clutch from Tractor Supply was around $95.
If you go this route you may need to shorten your PTO shaft slightly due to the added length of the clutch.
It takes a little time to install the clutch, make sure you PTO shaft is the right length and set the clutch up to slip where you want it to, but it is worth it.
UNUSED WOLVERINE 3PT QUICK HITCH (A64281)
UNUSED WOLVERINE...
UNUSED SWICT 84" BUCKET (A64280)
UNUSED SWICT 84"...
Caterpillar 215 Excavator Parts and Service Manuals (A63117)
Caterpillar 215...
Kubota V3600-T-E2 Turbo Diesel Engine - 3.6L - 84 HP - 2018 - Tier 2 - Pump Takeout (A63689)
Kubota V3600-T-E2...
2021 Chevrolet Silverado 2500HD 4x4 Crew Cab Pickup Truck (A61573)
2021 Chevrolet...
2023 NISSAN ALTIMA SEDAN (A59912)
2023 NISSAN ALTIMA...
