How do I build it? (Accumulator)
   / How do I build it? (Accumulator) #1
thendrix
ball ground, ga
allis chalmers ca
Bale Rig Simplifies Haymaking - YouTube
Not looking to copy this accumulator but the end result is what I'm looking for. I'm a small hay producer, about 20 acres twice a year, and I'm also chicken farmer and these two farms are about 10 miles apart so anything to speed things up in the hay field for cheap is a great thing. I don't mind building a 3 point setup but I have an odd sized trailer frame I could use. It's a 3x9 frame with a single axle. I currently have a 1980 Long 610 (70hp) with 1 remote and 540 PTO. I like this table style accumulator better them the type that drags across the ground. I've looked into the bale baskets but with my hilly ground I'm afraid they'd be to top heavy. Also there's not any in this area. Same goes for the new holland bale wagons. So I'm looking to build this setup as cheap as possible. Any ideas on how to go about this setup?
   / How do I build it? (Accumulator) #2
I like the one that just hooks on the front of a skid loader. It does slide on the ground but you only need one, not an accumulator and a grapple. Take a look at the W. R. long Graplelator. Ed
I think I've decided to go a different route. Sort of a scale down version of the Kuhns 15 bale. It's all mechanical. No hydraulics. No electronics. It works by the bales going up a chute and down an incline and tripping mechanical levers to guide the following bales.
10,000 PSI AIR HYDRAULIC PUMP (A58214)
10,000 PSI AIR...
2012 PROCO 130BBL VAC TRAILER (A58214)
2012 PROCO 130BBL...
2475 (A60432)
2475 (A60432)
2001 Dorsey 48ft Flatbed T/A Trailer (A56857)
2001 Dorsey 48ft...
2025 GPS Trailer (A56857)
2025 GPS Trailer...
2019 CATERPILLAR D6K2 LGP CRAWLER DOZER (A60429)
2019 CATERPILLAR...
