Rotary Cutter how can I remove cutter assembly?
/ how can I remove cutter assembly? #1
walter c lenoir
TC35
I have a 5' brush hog (tuffy 5 I think) and I'm replacing the underneath cutting assembly. I can't get the assembly off the shaft after the nut is removed. Is there a puller for this? thanks,
/ how can I remove cutter assembly? #2
Try tapping through the blade access holes on top of the deck. Hit a few times then turn the pan 180 degrees/repeat. This worked on my Frontier RC1072 a couple days ago :thumbsup:
/ how can I remove cutter assembly? #3
Put the nut part of the way back onto the shaft. If it has a provision for a cotter pin, put one in. If it's a self-locking nut, thread it on far enough so that the nut won't fall off. Just make sure that it's not tight against the stump-jumper, blade holder, whatever it is. Engage the pto and run it. It will come loose.
/ how can I remove cutter assembly? #4
That is to easy. :thumbsup::thumbsup:
If that works I am embarressed by all the hammering, pounding, and hub puller improvising I have done in the past.
Next time I will try that first. Thanks for the great tip.
Tried it didn't work. Even hit a few stumps to try and knock it loose. I've had it off before, but it must have really sealed up. Thanks for advice. Walt
/ how can I remove cutter assembly? #6
Did you set the shaft end down on a a solid piece of oak when you tried Rockgod's suggestion?
/ how can I remove cutter assembly? #7
IIRC, that's a tapered shaft. It's really hard to break them loose, but that will usually do it.
How long did you run it? You may just have to do it some more. Do you have a neighbor that needs some mowing done? ;)
Another question, but did you back off the nut several turns? (plenty of room for the stump-jumper to drop down the shaft)
/ how can I remove cutter assembly? #8
and when you put it back on.. neverseize it.. :)
/ how can I remove cutter assembly? #10
I used 2 short pieces of chain with round loops on them, put the loops on the top of blade nuts. Loosened nut on blade carrier part of the way, hooked the chains together and set a 20 ton hydraulic on the chain, as it started up I slid a flat piece of metal between jack and nut.Got back out of the way and kept jacking. It popped loose and slid down against the nut.
/ how can I remove cutter assembly? #11
I made a puller.
take A stout piece of steel, perhaps quarter inch L channel. Cut a piece an inch or so longer then the rotor and cut (torch) or drill holes in the ends to match the blade bolt holes in the rotor. Cut or drill a center hole.
Place a bolt with a head sized to fit inside the center hole on the rotor, but big enough the cover most of the end of the splined spindle.
(I am making some assumptions here as to the rotor and spindle construct. My mowers are JDs which are all built about the same)
Bolt everything up with the center bolt of the "puller" pressing on the center of the spindle, (but not on the rotor), and pulling on the ends of the rotor with stout nuts, bolts washers. "Even" things all up, side to side and then take turns torquing down on each end bolt, while whacking the center bolt with a BFH.
Be careful to stand aside while doing this (I suspend my mower from a chain fall so I can get easy access) as with enough pressure on the puller, the whole rotor and puller will "pop" off the spindle with plenty of force.
The other method I have used with success is taking a heavy pipe 5 feet or so long, that is small enough to fit inside the bolt access holes in the top of the deck. with the center bolt out and the blades off, deck on the ground, drop that pipe through the access hole hitting the ends of the rotor alternatively, HARD, several times.
This has worked for me, especially on mowers with long rotors.
good luck.
/ how can I remove cutter assembly? #12
that was gonna be my next sugestion.. hyd puller.. :)
soundguy
Heavy Duty Pipe (A62679)
Heavy Duty Pipe...
New/Unused Landhonor 21ft x 13ft Metal Carport (A65583)
New/Unused...
ALUMINUM TOOLBOX (A64277)
ALUMINUM TOOLBOX...
New/Unused AGT Industrial SDA-140W Mini Wheel Loader (A65579)
New/Unused AGT...
1999 International F-8100 Truck (A62613)
1999 International...
John Deere 6200 Tractor (A64047)
John Deere 6200...
