Sprayer How can I hook up this attachment
   / How can I hook up this attachment #11
/pine is correct...use the drawbar that extends from under the rear axle to the rear...use a hitch pin to drop thru the hole in the drawbar after you have positioned the tongue of the sprayer over/under it. Secure pin to drawbar with a clip so it does not ride up and drop out. All this can be obtained at Tractor Supply and other places. Just a couple of bucks.
Hitch Pin, 3/4 in. dia. x 4-1/4 in. Usable Length - 0269109 | Tractor Supply Company
   / How can I hook up this attachment #12
In case you might not know.........this is a drawbar
Cross Drawbar, Category 1, 3/4 in. dia. - 0288975 | Tractor Supply Company
OK OK already!
This is a CROSS DRAWBAR (as the link / page says) that can be used between the arms of a Cat 1 3 pt hitch
my error...shoot me
   / How can I hook up this attachment #13
OK OK already!
my error...shoot me
And don't forget the anti-rotation lock is required...
The tractor's drawbar would be easier to rig up to, IMHO.
   / How can I hook up this attachment #15
That sprayer (in the link) looks like it's built for a lawn tractor. The hitch clevis looks like it's too small for a standard draw bar.
Roy is right as is everybody else. Drawbar as advertised....then use very short pieces of pipe within a pipe to reduce the size of the hole on your drawbar for that small pin that's going into a big hole...otherwise you'll beat the pin and the tongue of the sprayer to death. This is the same idea they use to match cat 1 attachments to cat 2 holes (big versus small or vice versa). Be careful using it on a slope as the fluid moves "down hill" in the tank...had a neighbor turtle his...has a relatively narrow wheel base.
My neighbors use those sprayers for small gardens and they usually pull them behind a mower.
   / How can I hook up this attachment #18
I would just use a trailer hitch drawbar in my three-point receiver hitch (which is made out of a "cross drawbar"). I have a receiver hitch on my lawn tractor and that's what I use to pull my sprayer.
   / How can I hook up this attachment #19
Runner, what are the pieces you welded on each side of the drawbar used for?
   / How can I hook up this attachment #20
"Runner, what are the pieces you welded on each side of the drawbar used for? "
They, in addition to the holes in the part that extends upward from the top hook, are mounting points for three-point equipment that won't work with a quick hitch. I also use them to attach my boom pole.
2019 Chevrolet Tahoe SUV (A55853)
2019 Chevrolet...
2009 Ford E-450 Ambulance (A55852)
2009 Ford E-450...
2016 Chevrolet Tahoe SUV (A55853)
2016 Chevrolet...
2016 MACK CXU613 MID-ROOF SLEEPER (INOPERABLE) (A55745)
2016 MACK CXU613...
2012 COMPTANK  ACID TRANSPORT TRAILER (A55745)
2012 COMPTANK...
Kubota RTV-X900 4x4 Diesel Utility Cart (A55851)
Kubota RTV-X900...
