Sprayer How can I hook up this attachment
   / How can I hook up this attachment #11
/pine is correct...use the drawbar that extends from under the rear axle to the rear...use a hitch pin to drop thru the hole in the drawbar after you have positioned the tongue of the sprayer over/under it. Secure pin to drawbar with a clip so it does not ride up and drop out. All this can be obtained at Tractor Supply and other places. Just a couple of bucks.
Hitch Pin, 3/4 in. dia. x 4-1/4 in. Usable Length - 0269109 | Tractor Supply Company
   / How can I hook up this attachment #12
In case you might not know.........this is a drawbar
Cross Drawbar, Category 1, 3/4 in. dia. - 0288975 | Tractor Supply Company
OK OK already!
This is a CROSS DRAWBAR (as the link / page says) that can be used between the arms of a Cat 1 3 pt hitch
my error...shoot me
   / How can I hook up this attachment #13
OK OK already!
my error...shoot me
And don't forget the anti-rotation lock is required...
The tractor's drawbar would be easier to rig up to, IMHO.
   / How can I hook up this attachment #15
That sprayer (in the link) looks like it's built for a lawn tractor. The hitch clevis looks like it's too small for a standard draw bar.
Roy is right as is everybody else. Drawbar as advertised....then use very short pieces of pipe within a pipe to reduce the size of the hole on your drawbar for that small pin that's going into a big hole...otherwise you'll beat the pin and the tongue of the sprayer to death. This is the same idea they use to match cat 1 attachments to cat 2 holes (big versus small or vice versa). Be careful using it on a slope as the fluid moves "down hill" in the tank...had a neighbor turtle his...has a relatively narrow wheel base.
My neighbors use those sprayers for small gardens and they usually pull them behind a mower.
   / How can I hook up this attachment #18
I would just use a trailer hitch drawbar in my three-point receiver hitch (which is made out of a "cross drawbar"). I have a receiver hitch on my lawn tractor and that's what I use to pull my sprayer.
   / How can I hook up this attachment #19
Runner, what are the pieces you welded on each side of the drawbar used for?
   / How can I hook up this attachment #20
"Runner, what are the pieces you welded on each side of the drawbar used for? "
They, in addition to the holes in the part that extends upward from the top hook, are mounting points for three-point equipment that won't work with a quick hitch. I also use them to attach my boom pole.
2017 MEC 1930SE 19ft Scissor Lift (A55851)
2017 MEC 1930SE...
2015 GMC Acadia SUV (A55853)
2015 GMC Acadia...
2018 Jeep Grand Cherokee SUV (A55853)
2018 Jeep Grand...
2015 Kia Cadenza Sedan (A53424)
2015 Kia Cadenza...
2008 PARKER  25 T/A GOOSENECK (A55745)
2008 PARKER 25...
2007 FREIGHTLINER COLUMBIA 120 (A55745)
2007 FREIGHTLINER...
