How big or little - a SCUT...maybe a BX1880?
   / How big or little - a SCUT...maybe a BX1880?
Here are a few - delivery on Monday!
@airbiscuit and @LS mt125 owner,
I had planned to get a tooth bar...and the ratchet rake suggestion came up on this thread - that could be a good fit. But apparently the ratchet rake is not really for digging. So maybe I would need an easy on/off tooth bar so that I could swap it out with the ratchet rake as needed...if there is such a tooth bar...?
   / How big or little - a SCUT...maybe a BX1880? #53
   / How big or little - a SCUT...maybe a BX1880? #54
Based on your original post, I think you will use the PTB much more and likely leave it on all of the time. If for some reason you find you can't do what you want with the PTB, then get RR. The problem I see with the RR is you will be taking it off and on and it isn't a good digger.
Yep - thanks!
LOT LOCATIONS (A59575)
207274 (A52708)
207274 (A52708)
AUCTION STARTS HERE @ 9AM (A60429)
AUCTION STARTS...
2004 INTERNATIONAL 7400 20FT TANDEM AXLE FLAT BED (A59575)
2004 INTERNATIONAL...
2012 TOP HAT TRAILER GOOSENECK FLATBED TRAILER (A58214)
2012 TOP HAT...
2022 John Deere Z930M (A57148)
2022 John Deere...
