How big or little - a SCUT...maybe a BX1880?
   / How big or little - a SCUT...maybe a BX1880?
Here are a few - delivery on Monday!
@airbiscuit and @LS mt125 owner,
I had planned to get a tooth bar...and the ratchet rake suggestion came up on this thread - that could be a good fit. But apparently the ratchet rake is not really for digging. So maybe I would need an easy on/off tooth bar so that I could swap it out with the ratchet rake as needed...if there is such a tooth bar...?
   / How big or little - a SCUT...maybe a BX1880? #53
   / How big or little - a SCUT...maybe a BX1880? #54
Based on your original post, I think you will use the PTB much more and likely leave it on all of the time. If for some reason you find you can't do what you want with the PTB, then get RR. The problem I see with the RR is you will be taking it off and on and it isn't a good digger.
Yep - thanks!
(4) 320 x 90 R50 Tires and Rims (A50514)
(4) 320 x 90 R50...
2007 Reitnouer 40 Ton T/A Flatbed Trailer (A49461)
2007 Reitnouer 40...
2007 FORD F-750XL SUPER DUTY DUMP TRUCK (A50459)
2007 FORD F-750XL...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A51039)
80in HD Tooth...
PORTA CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTA CABLE 150...
2015 FREIGHTLINER CASCADIA DAY CAB (A51219)
2015 FREIGHTLINER...
