How big or little - a SCUT...maybe a BX1880?
   / How big or little - a SCUT...maybe a BX1880?
Here are a few - delivery on Monday!
@airbiscuit and @LS mt125 owner,
I had planned to get a tooth bar...and the ratchet rake suggestion came up on this thread - that could be a good fit. But apparently the ratchet rake is not really for digging. So maybe I would need an easy on/off tooth bar so that I could swap it out with the ratchet rake as needed...if there is such a tooth bar...?
   / How big or little - a SCUT...maybe a BX1880? #53
   / How big or little - a SCUT...maybe a BX1880? #54
Based on your original post, I think you will use the PTB much more and likely leave it on all of the time. If for some reason you find you can't do what you want with the PTB, then get RR. The problem I see with the RR is you will be taking it off and on and it isn't a good digger.
Yep - thanks!
FORD F550 SUPER DUTY SERVICE TRUCK (A52707)
FORD F550 SUPER...
8 TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
8 TOOTHED BUCKET...
TANK MANIFOLD (A58214)
1998 PRATT ISO DROP FRAME TRAILER (A59575)
1998 PRATT ISO...
Deere 333G (A53317)
Deere 333G (A53317)
20800 (A56859)
20800 (A56859)
