How big or little - a SCUT...maybe a BX1880?
   / How big or little - a SCUT...maybe a BX1880?
Here are a few - delivery on Monday!
@airbiscuit and @LS mt125 owner,
I had planned to get a tooth bar...and the ratchet rake suggestion came up on this thread - that could be a good fit. But apparently the ratchet rake is not really for digging. So maybe I would need an easy on/off tooth bar so that I could swap it out with the ratchet rake as needed...if there is such a tooth bar...?
   / How big or little - a SCUT...maybe a BX1880? #53
   / How big or little - a SCUT...maybe a BX1880? #54
Based on your original post, I think you will use the PTB much more and likely leave it on all of the time. If for some reason you find you can't do what you want with the PTB, then get RR. The problem I see with the RR is you will be taking it off and on and it isn't a good digger.
Yep - thanks!
2021 Kubota SVL75-2 Track Loader (A56438)
2021 Kubota...
2014 International WorkStar 7300 4x4 Altec AA55E 55ft. Material Handling Bucket Truck (A60460)
2014 International...
8065 (A55852)
8065 (A55852)
CAT D8 (A58214)
CAT D8 (A58214)
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59904)
2019 FREIGHTLINER...
2023 Fat Truck 2.8C Amphibious AWD Off-Road Utility Vehicle (A55852)
2023 Fat Truck...
