How big a CB for block heater?
/ How big a CB for block heater? #1
Haywire
Central Kentucky
Tractorless :(
My BX complained this morning when I started it at 19 deg. It cranked right up, but knocked and smoked for a minute. I think I am going to get a block heater for it and need to run some AC out to the wood shed. Need some lights out there anyway. How much current do those heaters pull? Is 12/2 and a 20 amp breaker plenty?
Ian
/ How big a CB for block heater? #2
Ian
Plenty. That will give you a circuit for other, high draw tools as well.
I assume you glowed your plugs? In 3 series of 8 Mississippis?:D
/ How big a CB for block heater? #3
Ian
Your question cannot be answered properly without knowing how far the wood shed is from the service panel.
/ How big a CB for block heater? #4
The block heater plugs into a standard 15 amp receptacle. the distance from house ( source ) is important. Voltage drop !!!!
If you are going to trench, then a conduit may work for you, extra wiring for maybe switching lights @ house and shed. A 8 circuit panel in the shed ?
Consider another building in the future? Workshop ?
If you are trenching maybe a 1/2" or 3/4" poly pipe for water ?
I'll be running it from the barn, which has a 120A panel in it that someone contributed when I wired it (upgraded from a small 6 or 8 circuit panel). The outlet will be about 60 feet from that panel. The barn panel is fed from a 100A 220v breaker in the house panel via 4ga copper. House is about 50yds from the barn. I know, probably not code, but the barn was fed like that when I bought the house.
Ian
/ How big a CB for block heater? #7
The block heater in my B7610 draws 400 Watts (3.3A). It is likely the same for the BX.
/ How big a CB for block heater? #8
The heaters that are fit in a radiator hose will draw a bit more, as will the typical magnetic type oil pan heaters. Those that screw directly into a freeze plug type fitting generally draw a bit less. YMMV.
/ How big a CB for block heater? #9
Hope that barn sub-panel ground is run properly-most are not. Should not be bonded to the main panel and have it's own ground rod as should the shed.
Both. The 3 conductor feed cable is tied to the house panel ground and there is an additional solid copper grounding cable going to a rod at the barn.
Ian
Good... no problem then. I asked the dealer and they didn't seem to know. Didn't have one on hand to look at.
thanks,
Ian
/ How big a CB for block heater? #12
Based on the distance, #12 wire on a 20 amp breaker should be just fine.
/ How big a CB for block heater? #13
DITTO,
Make sure the block heater is no less than 400 watts.
When I needed to change mine, the clerk said that 200 was all that could be had.
It simply was not enough and I had to re-install a 400 watt unit.
Maybe 200 is OK for a Gasser but just did not cut it at -25 on my diesel
NB; I also found the hard way that with snow GFI's are not that great.
You know that you are plugged in only to find that snow tripped that sensitive GFI.
I got fedup resetting and installed regular outlet.
/ How big a CB for block heater? #14
Yeah, my M5040 acted like that yesterday. But it's been a while since it's been started. Fortunately, it came with a block heater and I have electric in the barn, so it got plugged in last night.
I thought it unusual that the tractor came with a block heater, none of my other equipment is like that.
Ken
2022 SANY SY35U EXCAVATOR (A63276)
2022 SANY SY35U...
12' x 76" Tilt Flatbed Utility Trailer (A66285)
12' x 76" Tilt...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
44in Single Cylinder Grapple Bucket Skid Steer Attachment (A64553)
44in Single...
2006 Toyota Tacoma (A66408)
2006 Toyota Tacoma...
213087 (A64276)
213087 (A64276)
