How big a CB for block heater?
/ How big a CB for block heater? #1
Haywire
Veteran Member
Central Kentucky
Tractorless :(
My BX complained this morning when I started it at 19 deg. It cranked right up, but knocked and smoked for a minute. I think I am going to get a block heater for it and need to run some AC out to the wood shed. Need some lights out there anyway. How much current do those heaters pull? Is 12/2 and a 20 amp breaker plenty?
Ian
/ How big a CB for block heater? #2
Ian
Plenty. That will give you a circuit for other, high draw tools as well.
I assume you glowed your plugs? In 3 series of 8 Mississippis?:D
/ How big a CB for block heater? #3
Ian
Your question cannot be answered properly without knowing how far the wood shed is from the service panel.
/ How big a CB for block heater? #4
The block heater plugs into a standard 15 amp receptacle. the distance from house ( source ) is important. Voltage drop !!!!
If you are going to trench, then a conduit may work for you, extra wiring for maybe switching lights @ house and shed. A 8 circuit panel in the shed ?
Consider another building in the future? Workshop ?
If you are trenching maybe a 1/2" or 3/4" poly pipe for water ?
I'll be running it from the barn, which has a 120A panel in it that someone contributed when I wired it (upgraded from a small 6 or 8 circuit panel). The outlet will be about 60 feet from that panel. The barn panel is fed from a 100A 220v breaker in the house panel via 4ga copper. House is about 50yds from the barn. I know, probably not code, but the barn was fed like that when I bought the house.
Ian
/ How big a CB for block heater? #7
The block heater in my B7610 draws 400 Watts (3.3A). It is likely the same for the BX.
/ How big a CB for block heater? #8
The heaters that are fit in a radiator hose will draw a bit more, as will the typical magnetic type oil pan heaters. Those that screw directly into a freeze plug type fitting generally draw a bit less. YMMV.
/ How big a CB for block heater? #9
Hope that barn sub-panel ground is run properly-most are not. Should not be bonded to the main panel and have it's own ground rod as should the shed.
Both. The 3 conductor feed cable is tied to the house panel ground and there is an additional solid copper grounding cable going to a rod at the barn.
Ian
Good... no problem then. I asked the dealer and they didn't seem to know. Didn't have one on hand to look at.
thanks,
Ian
/ How big a CB for block heater? #12
Based on the distance, #12 wire on a 20 amp breaker should be just fine.
/ How big a CB for block heater? #13
DITTO,
Make sure the block heater is no less than 400 watts.
When I needed to change mine, the clerk said that 200 was all that could be had.
It simply was not enough and I had to re-install a 400 watt unit.
Maybe 200 is OK for a Gasser but just did not cut it at -25 on my diesel
NB; I also found the hard way that with snow GFI's are not that great.
You know that you are plugged in only to find that snow tripped that sensitive GFI.
I got fedup resetting and installed regular outlet.
/ How big a CB for block heater? #14
Yeah, my M5040 acted like that yesterday. But it's been a while since it's been started. Fortunately, it came with a block heater and I have electric in the barn, so it got plugged in last night.
I thought it unusual that the tractor came with a block heater, none of my other equipment is like that.
Ken
Landhonor 48" Galvinized Fence (A66408)
Landhonor 48"...
New/Unused Electric Winch (A65583)
New/Unused...
Ford Pickup Truck Bed (A64556)
Ford Pickup Truck...
Case IH 181 Rotary Hoe (A66408)
Case IH 181 Rotary...
Heavy Duty Steel Baskets (A65579)
Heavy Duty Steel...
350 Block Engine (A65579)
350 Block Engine...
